DiscoHere Posted December 21, 2014 Share Posted December 21, 2014 Hi all My 2003 Disco 2 has developed an annoying habit. Sometimes when i turn the key all i get is a click instead of a turnover. It has started when I persist every time to-date but i am worried it will someday let me down fully. Otherwise working perfectly All suggestions welcome By the way it has been very wet and i was wading (shallow) yesterday. Maybe something to do with water???? Thanks Hugh Quote Link to comment Share on other sites More sharing options...
dave88sw Posted December 21, 2014 Share Posted December 21, 2014 Very common problem, the solenoid on the starter motor fails due to dirty contacts, you can get rebuild kits but to be honest, a new starter isn't massively expensive and i've done a few that have given up again shortly after. While you're there, check that the fuel pressure regulator isn't leaking as sometimes a leaky regulator pours diesel over the starter and kills it. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 21, 2014 Share Posted December 21, 2014 I bought a rebuild kit and it lasted the 30k miles until the vehicle went ... fitted it in situ, which was a bit fiddly but ok. Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted December 21, 2014 Author Share Posted December 21, 2014 Thanks for that. I will check it out and replace if needs be Hugh Quote Link to comment Share on other sites More sharing options...
