dazza4x4 Posted October 20, 2014 Share Posted October 20, 2014 Hi everyone. Know quite a lot about disco's, but this is my first auto. Can't engage diff lock, and when in park or neutral, diff lock ligh is on, checked and is defiately not engaged. Looking at rave manual there is mention of an engagement solenoid, has anyone else had this problem. All suggestions greatly appreciated. cheers Dazza Quote Link to comment Share on other sites More sharing options...
hangover Posted October 21, 2014 Share Posted October 21, 2014 If the difflock actuator is stuck you may need to reverse then go forward to engage/ dis-engaged the lock. Generally i can slot it in while slowly rolling in neutral , the engagement solenoid will only be for the dash light so you want to make sure it is locking and unlocking properly. Quote Link to comment Share on other sites More sharing options...
dazza4x4 Posted October 23, 2014 Author Share Posted October 23, 2014 Thanks for that, managed to sort diff lock, not the usual siezed bar, but the whole shift box. Still got light on in park and neutral when disengaged. Light on full time when engaged. Does anyone else with an auto have this problem Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 25, 2014 Share Posted October 25, 2014 Not since I converted to a R380, but when I had the ZF4HP22 yes, what I found was the switch was sticking, I would engage the Diff-lock and the light remained on even after I had dis-engaged it, after a couple of miles and a few bumps it would turn off, the easy solution is to replace the switch, the hard part is getting to the little sucker from above once the sheet metal cover under the transmission cover console has been removed, arround 3 hours work for a 2 minute switch change !!! Quote Link to comment Share on other sites More sharing options...
dazza4x4 Posted October 26, 2014 Author Share Posted October 26, 2014 Thanks for that, just been out getting car dirty, and diff lock engaging and disengaging fine. Will have a look at switch when i get time, got a full disco for spares, so might just do a swap to make sure Quote Link to comment Share on other sites More sharing options...
dazza4x4 Posted November 7, 2014 Author Share Posted November 7, 2014 problem sorted, was a dodgy switch. Cheers fore the help Dazza Quote Link to comment Share on other sites More sharing options...
