Boydie Posted October 6, 2015 Share Posted October 6, 2015 Western, Could you tell me the length and thread sizes of the studs it calls up on the removal of the transfer box. 18G 1425 ? with a bit of luck I'm hoping that I can use some old cylinder head bolts cut down but I'd like to know beforehand just what they are. Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2015 Share Posted October 6, 2015 attachments for transfer box to main gearbox items 37 to 41 in http://lrcat.com/#31/4/5375only gives thread type & length doesn't show thread pitch. guide studs --- found this ------------ http://www.lrrforums.com/showthread.php?21708-LT230-Guide-studs-part-number-quot-18G-1425-quot Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 6, 2015 Author Share Posted October 6, 2015 Thanks Western, I'll obtain a couple of 9 1/4 long 10 x 1.5 bolts and cut the heads off and see how that goes and get back to you should you be asked the question again. Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2015 Share Posted October 6, 2015 hope it works ok, if all good, might add this to tech archive for future reference Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 9, 2015 Author Share Posted October 9, 2015 Western, Yes, the bolts are m10 x 1.5mm pitch, three are required and all are 6 1/4" long including the thread. I used 8.8 tensile bolts and they were fine, stronger ones would, if available tend to bend less. I'll let you know how good they are in aligning the two boxes to avoid damage to the input seal on the transfer box when I get to that stage. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 9, 2015 Share Posted October 9, 2015 I've done this myself, made the job 10 times easier, have the bolts in a box somewhere with slots cut in the end to aid removal... Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 13, 2015 Author Share Posted October 13, 2015 I ground down the ends making two flats to suit an 8mm spanner, same result, different way of doing it . Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 14, 2015 Author Share Posted October 14, 2015 On the Disco, I found that the best method for determining the correct length was to screw the studs into the gearbox and then measure them so that they are 1/4"-1/2" longer than the R380 output shaft. If the studs are any longer than that and the transfer box fouls with the transmission tunnel as the studs prevent it from being lifted up. Quote Link to comment Share on other sites More sharing options...
