hillyseries Posted August 24, 2014 Share Posted August 24, 2014 I have a series 3 88", I've replace the break lines, master cylinder, shoes, slave cylinder(pistons) springs, adjuster, a wole new system. when I apply the breaks the shoes do not return & lock on the only way of releasing them is to open a bleed nipple & relapse the pressure. The system is a single pipe system , with no servo. Any advice gratefully received Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted August 24, 2014 Share Posted August 24, 2014 Very possibly you have not left slack in the system, between the pedal and the piston in the master cylinder. This means the piston does not return fully to the 'rest' position, so the port between the master cylinder and the reservoir is not opened. This means the extra fluid you pushed into the system cannot return, pushed by the shoe pull off springs. Remove any pedal mounted pull-off spring, then shorten the effective length of the pushrod until you can feel a touch of slack movement in the pedal. This will be covered in the Workshop Manual, but you may not have recognised the significance. HTH Quote Link to comment Share on other sites More sharing options...
hillyseries Posted August 24, 2014 Author Share Posted August 24, 2014 Thank you for the advice, I'd tried everything other than altering the push rod length, I'll give it ago Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted August 24, 2014 Share Posted August 24, 2014 Just to add to David's post - the pedal must be free to return to its stop. If it doesn't the recuperating system in the master cylinder won't work. (When the pedal is released fully the valve in the cylinder should be open to allow the fluid to return and rest at atmospheric pressure.) Quote Link to comment Share on other sites More sharing options...
hillyseries Posted August 24, 2014 Author Share Posted August 24, 2014 Thank you both for your advice, 1st time ive used the forum, brakes now unlocking after use, although pedal goes to floor 1st time of use then ok after, I'm hoping to cure this on adjusters. Much appreciated Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted August 30, 2014 Share Posted August 30, 2014 It seems if the pedal pumps up on rapid application - its adjustment. If it won't its air in the system. Quote Link to comment Share on other sites More sharing options...
hillyseries Posted September 2, 2014 Author Share Posted September 2, 2014 Thanks to all for your assistance, brakes now fully operational Quote Link to comment Share on other sites More sharing options...
