smokin
whippet
hi all I have an 02 td4 its now done 189800 miles its started to smoke a bit (blue) sometimes belching blue smoke when driving sometimes not after ticking over for a time seems worse but it does clear up any ideas ( new member)
If yours is smoking it might be beyond it, the crank breather filters are often overlooked but if they are blocked bad stuff happens, I can't remember if it starves the turbo of oil or causes a buildup of pressure somewhere...
Part is LLJ500010 - DEPRESSION CONTL FILTER ASSY TD4 F/L
http://www.brit-car.co.uk/product.php/99148/0/depression_contl_filter_assy_td4_f_l
or for cheapness:
http://www.brit-car.co.uk/product.php/206390/0/depression_contl_filter_assy_td4_f_l
thanks again fridgefreezer, job done as you say its quite easy BUT, when removing the filter/valve cover it fouled on the fuel return pipe breaking two of the plastic T pieces which cost £30 to replace grrrrrrr :angry: but it looks like its stopped smokin :D thanks again for the help
