Laddy Posted June 19, 2014 Share Posted June 19, 2014 Hi, my first time on the forum. I own a 2004 1.8 petrol that has done about 130' k. Removed prop shaft to change noicy bearings and the VCU which was getting rather stiff. Drive 2wd now and when the noicy bearing was out of the way, all of a sudden I hear new noices from under the front of the car. 1st gear ok, 2nd gear ok, 3rd gear some noice on low speed and low revs, 4th and 5th gear a lot of rumbling noice on low revsu my foot down going up hill. Goes silent when i come off the throtle. Over 2000 rpm and easy terrain - no sounds at all- Any ideas anyone? Quote Link to comment Share on other sites More sharing options...
Laddy Posted June 21, 2014 Author Share Posted June 21, 2014 Have I adressed the wrong forum? Any more information needed? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 23, 2014 Share Posted June 23, 2014 Diagnosing "it makes a noise sometimes" over the internet is quite tricky. Given that you say it's worse at low revs in high gear with your foot down, is it just the engine labouring because the revs are too low? Quote Link to comment Share on other sites More sharing options...
Laddy Posted June 23, 2014 Author Share Posted June 23, 2014 Thanks for the response. Your offcourse right about diagnosing sounds over the internet. I dont think it's the engine making the sounds. I have had other FL,s and never heard this kind if noice. Have read somthing about counter weights on the gear shift mechanism making resonance sounds. Some suggest it might be the inside of the catalyst comming loose. Metal to metal in engine mounts? I have changed the head gasket and the timing belt. Could it be "pinging" in low revs in case the ignition is not 100%? Quote Link to comment Share on other sites More sharing options...
