Carpy Posted November 4, 2014 Share Posted November 4, 2014 Hi newbie here looking at buying my first Freelander now i'll be using it off road a little bit nothing drastic just dirt tracks etc whilst I'm shooting ....now I've made up my mind to have a td4 the question manual or automatic is there much difference between them on m.p.g. ? on road ? thank's in advance Graham Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 5, 2014 Share Posted November 5, 2014 i may have one for sale shortly. engine has just been replaced with a lower mileage unit and other bits and bobs too. its an auto, the owner wants to get a newer one this is an 05 plate in bonatti grey (i think sport variety) with the leather trim, ill have words and see what they want to do, although its not quite finished yet, would come with 12 mths ticket though where abouts in the world are you? Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 5, 2014 Share Posted November 5, 2014 If you want to use it for off-road at all, auto. A manual cooks the clutch pretty quickly... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 5, 2014 Share Posted November 5, 2014 I'd agree with Elbekko for some of the tighter off-road stuff, the Freelander does suffer from a lack of low-range gearing off-road that an Auto will compensate for. That said I've off-roaded both my manuals and as long as you are aware of when you're abusing the clutch and don't overdo it (and stop & let it cool down if it starts to smell clutchy) it will live fine. Manual will give slightly better MPG. Quote Link to comment Share on other sites More sharing options...
Carpy Posted November 5, 2014 Author Share Posted November 5, 2014 Thank's for the replies :i-m_so_happy:I'm in Tamworth Staffs look's like an auto then if the difference in m.p.g. is minimal Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 5, 2014 Share Posted November 5, 2014 Auto's are slower, less fun to drive and typically lower mpg than manual counter parts. Off road, well some people just prefer manuals to auto's, but auto's can be very good. In the case of the Freelander however, the TD4 manual is WAAAAY to easy to stall. And the clutches suck on FL's for off road use. An auto will be better in this regard. If mpg isn't a major issue, check out a KV6 powered one. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 5, 2014 Share Posted November 5, 2014 If mpg isn't a major issue, check out a KV6 powered one. But if you do, make damned sure you know the issues with KV6's before buying, and it better be cheap! The diesels are at least fairly bulletproof engines whereas the petrols are great engines but with known issues that a lot of people don't fix properly. Quote Link to comment Share on other sites More sharing options...
Carpy Posted November 5, 2014 Author Share Posted November 5, 2014 Well lad's I bit the bullet this afternoon And I done something that I've never ever even thought about doing before ......I bought a none runner !!!! However there is a tale behind it and i'll be opening a new thread looking for advice !! I don't think it's a major issue and I bought it well cheap it's a 53 plate commercial special edition manual !!! I'm buzzing just need a good land rover mechanic now Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 6, 2014 Share Posted November 6, 2014 But if you do, make damned sure you know the issues with KV6's before buying, and it better be cheap! The diesels are at least fairly bulletproof engines whereas the petrols are great engines but with known issues that a lot of people don't fix properly. I've not heard of many issues with the KV6's. We've had two of those engines (MG ZS 180 and 825 Sterling) with no bother at all. As for the 1.8's, I think the internet highly inflates the issues with them too. Our 1.8 Freelander did need a HG doing, but was fine once done. Surprisingly it also wasn't much different on fuel compared to the Td4 Freelander that replaced it. That said, anyone buying a 1.8 should expect to do the HG at least once. But get it done right and they are cracking engines. Quote Link to comment Share on other sites More sharing options...
EggNChips Posted November 12, 2014 Share Posted November 12, 2014 My TD4 manual averages around 39 and never does less than 36, the 1.8 is listed at around 27. I would say that you had a fault with the TD4 if it was anywhere near the same as the 1.8. I had a TD4 auto a while back and it averged 32mpg I've not heard of many issues with the KV6's. We've had two of those engines (MG ZS 180 and 825 Sterling) with no bother at all. As for the 1.8's, I think the internet highly inflates the issues with them too. Our 1.8 Freelander did need a HG doing, but was fine once done. Surprisingly it also wasn't much different on fuel compared to the Td4 Freelander that replaced it. That said, anyone buying a 1.8 should expect to do the HG at least once. But get it done right and they are cracking engines. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 12, 2014 Share Posted November 12, 2014 My TD4 manual averages around 39 and never does less than 36, the 1.8 is listed at around 27. I would say that you had a fault with the TD4 if it was anywhere near the same as the 1.8. I had a TD4 auto a while back and it averged 32mpg I think LR only rate the TD4 at 37mpg average. So consistently bettering that would also sound odd. That said, use and driving style are probably the biggest factors that affect mpg. The TD4 usually does low 30's to around 35mpg. The 1.8 used to do highish 20's, maybe just into low 30's on a good run. A difference, but not a huge one, even less so when 95RON is cheaper than diesel. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 13, 2014 Share Posted November 13, 2014 I've found the TD4 drops to 28-32 ish when the airflow meter dies. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 13, 2014 Share Posted November 13, 2014 I've found the TD4 drops to 28-32 ish when the airflow meter dies. Thanks. I'll take a look at it. Quote Link to comment Share on other sites More sharing options...
