finwaz Posted November 6, 2014 Share Posted November 6, 2014 Can anyone help, the tailgate demister on my 2003 td4 which I have recently purchased isn,t working. The light on the switch comes on when you press it, but the heater doesn't,t work. On investigation I found one of the spade connectors had come off,so I reconnected it . whilst doing this I discovered that with the tailgate door open, the light on the switch doesn't come on. Does any one know if the demister only works with the tailgate shut or is there a fault ? Cheers Quote Link to comment Share on other sites More sharing options...
Lord_Unsub Posted November 22, 2014 Share Posted November 22, 2014 I think it's on a protective circuit. When I swapped the rear screen on mine after an unfortunate tip run incident.... I noticed while adjusting the glass in the holders, the window would only lower with the door open, not raise, and I imagine the heater is on the same interlock. You can fool it into working by flicking the catch mechanism over on the lock and trying it then. Good luck James Quote Link to comment Share on other sites More sharing options...
finwaz Posted November 22, 2014 Author Share Posted November 22, 2014 Ok I will try that ... Thanks Quote Link to comment Share on other sites More sharing options...
