Muttland Posted August 31, 2014 Share Posted August 31, 2014 Hello everyone: I need to buy in England 2 (REAR AXLE HALF SHAFT) for a Salisbury differential (later 300 tdi 2002 and pre Td5 110 Salisbury rear axles) Note: I dont know the VIN of the original defender, because this differential is in use in my S3 109 The codes that I have to order are: TOB500020 for the short shaft TOB500030 for the long shaft I do not know if I'm right. Can you confirm these code? thank you very much Enrique Quote Link to comment Share on other sites More sharing options...
western Posted August 31, 2014 Share Posted August 31, 2014 TOB500020 for the short shaft http://www.lrseries.com/shop/product/listing/12863/TOB500020-AXLE-SHAFT-REAR-RH.html TOB500030 for the long shaft http://www.lrseries.com/shop/product/listing/12864/TOB500030-REAR-AXLE-SHAFT-LH.html?search=TOB500030&page=1 see the info lower right on each page Quote Link to comment Share on other sites More sharing options...
Muttland Posted August 31, 2014 Author Share Posted August 31, 2014 Western: Thanks for your replay The original one is too expensive, in that case I will prefer the special steel Ashcroft options, but $$$$$$ is my limitation, Remember I need to Add the shipping price (+ - 90 £ for the courier to Uruguay) What do you thinks for the Bearcman options?: Western please tell me your optional brand for the similar price shown below. HALFSHAFT ASSY RHR 110 DEF Supplier: Bearmach | Brand: BM | Type: Pattern #TOB500020 £19.97 HALFSHAFT ASSY LHR 110 DEF Supplier: Bearmach | Brand: BM | Type: Pattern #TOB500030 £24.23 Enrique Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 31, 2014 Share Posted August 31, 2014 Hi, Although you saf the Salisbury diff is from a Defender, what is the axle from, Defender or Series? The Series LWB 24 spline Salisbury half shafts are 576767 and 576768. Quote Link to comment Share on other sites More sharing options...
Muttland Posted August 31, 2014 Author Share Posted August 31, 2014 missingsid The front axel is from defender too. But the front half shaft are very good in these case. The rear half shaft have "fretting corrosion'" in the exterior splines. And I have a couple of half shafts welded on flanges in use. But I prefer to switch to new Enrique Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 31, 2014 Share Posted August 31, 2014 Oh OK just checking Quote Link to comment Share on other sites More sharing options...
western Posted August 31, 2014 Share Posted August 31, 2014 The Bearmach branded shafts should be fine for your needs. if you order from LRSeries be sure to state which brand you want [bearmach] Quote Link to comment Share on other sites More sharing options...
Muttland Posted August 31, 2014 Author Share Posted August 31, 2014 External splines salisbury shaft imagenes gratis Internal splines Shaft: imag Quote Link to comment Share on other sites More sharing options...
Muttland Posted August 31, 2014 Author Share Posted August 31, 2014 Thanks Quote Link to comment Share on other sites More sharing options...
