300tdi revs but dies out.
hi all strange one this, while driving home at the weekend i noticed my 90 ( 300tdi auto) wasnt idiling the best and hunting when at a constant rev. i changed the fuel filter when i got home, no difference, in fact seemed to be getting worse no power at all and when held at a constant rev gradually died out.
i had a new lift pump in the drawer so i fitted it no difference,
checked the quality of the fuel supply lines, the main line to the lift pump wouldnt hold a vacuum, i thought thats me sorted.
changed the fuel line from tank to lift pump all good, started it up and still the same, revs for a minute or 2 the gradually dies out when being held at a constant rev, has anybody any ideas, before i pull the injection pump for a service,
cheers gary
1. Did you drain the sedimentor (if one's fit - I think they were standard for the deffer 300 tdi)?
2. Injectors given a clean recently?
3. You may have a split in the LDA diaghram.
4. But if it's hunting I'd suspect a split in the air cleaner hose.
