TD5 Fuel supply problem
Hi all.
Ive looked through the forums and got so far, but now Iam stuck and need some advice.
Ive got a 2000 defender TD5 110 station wagon. Couple of weeks ago the fuel pump started getting noisey
so I ordered a genuine LR pump. Before it arrived the 110 died as I dropped my kids off to football.
Got towed home by a friend, couldn't get it too restart, pump still noisey, but I figured the new pump
would be the answer.
Took the advice and cut a hole in the floor and the pump swap was relativley pain free, now for the first
interesting bit, found an old rag in the bottom of the tank, always check the tank!.
Anyway, couldn't get it restarted, purged, pumped the lot, pump still noisey though, the new pump!.
resorted to the AA and they got it started by using easy start into the turbo inlet.
Drove it down to my local specialist to se if he could sort it out.
Picked it up this morning, lots of purging etc he had got it running.
Drove to work, ran like a dream, I do love my 110.
Started it to come home, tickover for a minute then it died, not to restart!, tried damp start which
got it going but after a minute or so it died again.
Ended up on the back of an AA truck again.
now its down at the specialist, but since he could not find an actual problem last time, Iam hoping
to tax your brains!.
Fuel pump is nice and quiet, but it wont start, anyone ever had a blockage in a fuel pipe moving about?,
air leaks in the hoses?, I dont know what to do next?
Sorry about the saga story but Iam at my wits end.
I had similar problem when changing my pump. For any reason we don't know, there were two hoses sharing color, and we connect them in the wrong way. Also check fuel pump fuse for bad , sometimes it gets hot and fuel pùmp begins to judder. Finally, check the purge valve at the exit of the filter, maybe it's clogged...
check the fuel sedimentor [if fitted] it lives in the right rearwheel arch bolted to outer face of chassis, fuel filter, or it might be a immobiliser/spider unit fault.
Not fitted on the td5....the fuel filter is located there and needs changing first....loads of problems with filter housing air leaks and injector seals causing problems....get a pressure test done on the fuel system and let us know.
Thanks for the tips guys.
The fuel filter was changed at the last service in Spetember, but happy to try replacing it again.
It feels like an old Range rover I had that had a blocked fule pick up pipe, would run perfect for a few miles
then die, leave a while and it would go a few more miles, bascially using up the fuel in the line.
If someone had run it on 'chip fat' type diesel could that be solidify in the cold weather and blocking
the hea filter?.
Fuel hoses are right way round, checked that, then re checked!
Does the system air vent through the filter housing then, or somewhere in the tank?
also Ive read I hould have cleaned the tank out completley, but I just had a feel around for anything big?
Thanks again
Hi we had a td5 where the adjuster for the unit injector had it`s lock nut come loose and fall off resulting in the adjuster winding right off.I supect this had pust some carbon up inside the injector and holding it off its seat loosing pressure may be worth a look.
Phil.
the hea filter?.
Thanks again
There is a seperate vent on the tank, it has a non-return valve on it to keep fuel in when you park upside down.
Chip fat, SVO/WVO and TD5's dont mix, if it has ever been run on this then its a good starting point for the problems you are having.
Been there, done that. Does the fuel-pump make a "gurgling" or 'swishing' sort of noise as well as whining when it's priming? If so I'm betting you have failed copper seals on the injectors. Combustion gases get into the fuel system through the leaky seals - then the engine is trying to run on frothy fuel, which won't inject very well!
Right then the latest news is there is a load of crud and waterery mush in the bottom of the fuel tank
apparently the crud is hard but crumbles in your hand.
Since I had cut the access panel this is not as bad as it sounds!
Figuring out this crud bunged up the filter at the bottom of the pump and the only reason it ran for so long,
Ive done 10,000 this last year, is that I never let it go below quarter full, so fuel could get into the
top of hte swirl pot in the pump.
Anyway going to road test it tomorrow and then I put some miles on it to get my confidence back.
Will keep you informed.
Thanks to everyone for the help so far.
Cheers
  • 3 weeks later...
Right then gents, first of all thanks for all the advice.
My 110 is back and running, and so far so good.
The root of all the trouble seems to have been a load of water that had got into
the fuel tank at some point, obviously the diesel sits on top of the water, water cant
do anything but go rotten, it turns into some bacteria primeval soup, my new fuel pump
was great at moving diesel but not my newly discovered eco system.
Apparently seems this happens a lot in fuel oil storage tanks.
Anyway back to loving my Landy, but two words of advice Ive learnt and may help anyone
with fuel pump chahge on the cards.
First I managed the pump change via an acces hole in the floor, worked well especially
during the fault finding. Got some pics if anyone wants to cut holes in their landy, carefully!.
Second when you change the pump, enpty the tank and clean it out, good chance while you have
easy access.
Cheers
know in the aviation world as cladisporium resinae diesel is a very close relation to aviation kerosene fuel
Aviation fuel
Hydrocarbon utilizing microorganisms, mostly Cladosporium resinae and Pseudomonas aeruginosa, colloquially known as "HUM bugs", are commonly present in jet fuel. They live in the water-fuel interface of the water droplets, form dark black/brown/green, gel-like mats, and cause microbial corrosion to plastic and rubber parts of the aircraft fuel system by consuming them, and to the metal parts by the means of their acidic metabolic products. They are also incorrectly called algae due to their appearance. FSII, which is added to the fuel, acts as a growth retardant for them. There are about 250 kinds of bacteria that can live in jet fuel, but fewer than a dozen are meaningfully harmful.
  • 3 years later...
easy access.
Cheers
could I have some pictures of the hole you cut in the floor please, regards, harry
