engine problem urgent
defender dinky
yes done that now got steering casing off unscrewed ignition connection off the barrel turned ignition with screwdriver and car starts every time yet before had to hold key over and then it would start after a short time now in the barrel the rod that fits into ignition is wobbley and I can push it in about 5/6mm, would this cause the car to cut out as you moving along dd
