daveb500 Posted April 24, 2014 Share Posted April 24, 2014 Hi all, Just joined this forum, been a Land rover driver on and off for a few years. Just a quick question, what is the yellow relay in the top right corner as you look at it in the under dash fuse box. I cant find reference to in in Rave or in any hand book. On my freelander 1.8 it is opening and closing every few seconds. I have swapped it with another and still that position does the same. I am also struggling with the TC and HDC lights being on. Changed the brake switch, checked the 1st gear and reverse sensor, checked the gear shift switch. Had a TPS fault listed on OBD2 so put a new TPS and reset it. ABS works fine, tested that on a grassy field. cheers Quote Link to comment Share on other sites More sharing options...
