ELECTRIC ANTENNA FOR MY DISCO 1 1996
Muttland
Oddly enough, I have the exact same unit, there are two connections for the electric radio, the ariel and a power plug to activate the ariel when the radio is on and power it down when the radio, or ignition is turned off. I mounted mine on the front wing, if you select this location you need to remove the inner plastic panel to install it. Running the aerial cable and electric connections is a bit problematic, you will need a flexible plastic cable draw rod, they should reach the radio without any extensions but you will need to drill a hole for them to pass into the driver's (or passenger) footwell - make sure you fit a rubber grommet into the hole and seal it with silicon after.
