mcc1979ian Posted May 23, 2016 Share Posted May 23, 2016 Few questions, Where did you get the correct fuel lines? Where did you get oil cooler pipes? What exhaust downpipe suits? Does standard 300tdi coolant pipes fit? Any other advice?? Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 23, 2016 Share Posted May 23, 2016 I've done 300 into a ex diesel turbo 110 hi cap. Fuel lines I just spliced them at the bulkhead and riveted the disco fuel filter to the bulkhead. Oil pipes where from a 200tdi. Q Coolant pipes fitted I think one might have needed lengthening at the top hose but can't quite remember. Just made up an exhaust section with a flex joint in it. It was pretty easy mostly. Picture worth a thousand words... 1 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 24, 2016 Share Posted May 24, 2016 Why not do it properly with an r380 and putting the engine in the 300tdi position? It's easier in the long run as you can use off the shelf exhaust / coolant / oil pipes Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 24, 2016 Author Share Posted May 24, 2016 This ones just a run around for now and to be honest i never thought about the differing parts at first or id o just gone 200tdi Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 24, 2016 Author Share Posted May 24, 2016 I've done 300 into a ex diesel turbo 110 hi cap. Fuel lines I just spliced them at the bulkhead and riveted the disco fuel filter to the bulkhead. Oil pipes where from a 200tdi. Q Coolant pipes fitted I think one might have needed lengthening at the top hose but can't quite remember. Just made up an exhaust section with a flex joint in it. It was pretty easy mostly. Picture worth a thousand words... IMG-20160523-WA0005.jpg Pictures very helpful but one question. Where does the braided hose from the oil breather attach as i notice yours is inattached in the pic Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 24, 2016 Share Posted May 24, 2016 Well I used the air hoses from the disco which plumbed in pretty easily I was missing a fitting in that picture and just attached it to the normal place it goes to on a 300tdi (round the back of the engine and it T's into the turbo inlet hose. I didn't even look at using the original viscous fan, I just installed an electric one (and this is only needed when the truck was used to harrow the field). I was really quite impressed at the ease of how well it went in, and with very few modifications really. The PAS pipes I used a pipe cutter to crop the Disco hi pressure line and the original hi pressure line at a suitable place then I just re-joined them with a compression fitting. You can probably do the piping a lot tidier than what you see in the picture, but I was on a shoestring budget so just used what I could find in various piles of scrap parts - turns out I need little out with the donor and original engine parts. 1 Quote Link to comment Share on other sites More sharing options...
Boris113 Posted May 24, 2016 Share Posted May 24, 2016 Photobucket doesn't work from the office but I used 300tdi engine mounts which enabled the standard 300tdi downpipe to be used. A 300tdi disco air filter (square plastic one) sits on the inner wing just in front of the heater and is connected by a disco air intake pipe. Oil breather hose is the same as Maverik said above. Fuel pipes all married up with no problems and the fuel filter is mounted to the bulkhead inboard of the clutch master cylinder - seem to remember I used the 2.5td rivnuts in the bulkhead to mount it Radiator hoses were cut and extended with pieces of tube, a 200Tdi conversion top intercooler hose was the right length, the bottom is a mis-match of stainless tube/silicone but works fine. The PAS hoses seem to reach without needing extending but don't quite sit flat against the front crossmember. If you are interested I have a set of Steve Parker 300tdi extended oil cooler pipes that are still in the box? I'll try and post a couple of pictures later on Harry Quote Link to comment Share on other sites More sharing options...
Daan Posted May 24, 2016 Share Posted May 24, 2016 You know you need a 200 bell house do you? Daan Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 24, 2016 Share Posted May 24, 2016 I just used the standard 300 flywheel housing, you can't get all the bolts in from memory but you can get enough in or I wouldn't have done it... Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted May 24, 2016 Share Posted May 24, 2016 Hello there. I cut the center out of my 2.5 na flywheel housing to retain 300 tdi crank seal when matting it to an LT77. Seen it on the www. Meaning all bolts, studs and nuts engine to gearbox used. The engine does sit back a bit, had to do two 90 degree bends for the exhaust at the manifold one engine mount made up. Extended the oil cooler hoses power steering stretched. Used 2.5 na air filter mounted on a small cradle hung of where the air con (i think) would mount on a 300 tdi and pipe over to the turbo. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 24, 2016 Author Share Posted May 24, 2016 Photobucket doesn't work from the office but I used 300tdi engine mounts which enabled the standard 300tdi downpipe to be used. A 300tdi disco air filter (square plastic one) sits on the inner wing just in front of the heater and is connected by a disco air intake pipe. Oil breather hose is the same as Maverik said above. Fuel pipes all married up with no problems and the fuel filter is mounted to the bulkhead inboard of the clutch master cylinder - seem to remember I used the 2.5td rivnuts in the bulkhead to mount it Radiator hoses were cut and extended with pieces of tube, a 200Tdi conversion top intercooler hose was the right length, the bottom is a mis-match of stainless tube/silicone but works fine. The PAS hoses seem to reach without needing extending but don't quite sit flat against the front crossmember. If you are interested I have a set of Steve Parker 300tdi extended oil cooler pipes that are still in the box? I'll try and post a couple of pictures later on Harry How much you want for them? Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 24, 2016 Author Share Posted May 24, 2016 So far iv got the engine in using Steve parkers bolt on mount kit, using 300tdi flywheel housing, removed dowel and one lower stud from flywheel housing and mounted to 2.5na bellhousing. Got adapted on the turbo to stop the pipes rubbing on the bulkhead, replaced temperature sender to suit my gauge, power steering box is in and fitted up. Still got to do exhaust, air supply, oil cooler and fuel lines and get all the coolant and intercooler pipe work installed. Got a kenlowe lying in the garage so will be electric fan for me. 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 25, 2016 Share Posted May 25, 2016 ah well you've done the hard bits! 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted May 25, 2016 Share Posted May 25, 2016 The problem with using the 2.5 n/a bell housing is you cannot set the timing. This I know, because I have that bell housing also. I have a trick for this though. I cannot see the need to cut a hole to clear the crank seal, as the 200 and n/a has the same size crank seal journal. daan Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted May 25, 2016 Share Posted May 25, 2016 Got adapted on the turbo to stop the pipes rubbing on the bulkhead, It is a bit tight at the back but to be honest the discovery air pipe fits OK, have you done something better? For the exhaust downpipe I figured it as best to make the new downpipe in stainless so I wouldn't need to do it again for a long time. I made a new flange and tiged two 45 degree bends to clear the engine mount, after the stainless downpipe it all then interfaces to any standard (or custom) exhaust you choose. The old NA flywheel housing fits allowing you to use the old oil seal but cutting out the centre allows you to use the better 300 rear main oil seal - I'm pleased that I did that as many years on mine is still drip free. Also retain the dowels for locating the engine, the bolts hold it together ok but the dowels locate it accurately. Its only a few seconds with a reamer ( or even a file ) and makes for a better job than the oft suggested bodge of pulling them out. HTH Quote Link to comment Share on other sites More sharing options...
Boris113 Posted May 25, 2016 Share Posted May 25, 2016 How much you want for them? £45 sound ok? They are £62 on the website, I bought them from Steve Parker a year ago, they have oily finger prints on them but never been fitted and still in the original box. Sounds like you are cracking along with the conversion, keep up the good work Harry Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 25, 2016 Author Share Posted May 25, 2016 £45 sound ok? They are £62 on the website, I bought them from Steve Parker a year ago, they have oily finger prints on them but never been fitted and still in the original box. Sounds like you are cracking along with the conversion, keep up the good work Harry £45 sound ok? They are £62 on the website, I bought them from Steve Parker a year ago, they have oily finger prints on them but never been fitted and still in the original box. Sounds like you are cracking along with the conversion, keep up the good work Harry £45 sound ok? They are £62 on the website, I bought them from Steve Parker a year ago, they have oily finger prints on them but never been fitted and still in the original box. Sounds like you are cracking along with the conversion, keep up the good work Harry £45 good to me. Message me some payment details and I'll get ya paid. Cheers Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 27, 2016 Author Share Posted May 27, 2016 Borris113 you have a private message Quote Link to comment Share on other sites More sharing options...
Boris113 Posted May 28, 2016 Share Posted May 28, 2016 Sorry for the slow reply, been travelling with work. You have a PM Harry 1 Quote Link to comment Share on other sites More sharing options...
twodoorgaz Posted May 28, 2016 Share Posted May 28, 2016 I'd be really keen to see a close up of the two steve parker mounts in situ if you have time to take some pictures? Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 29, 2016 Author Share Posted May 29, 2016 Will get you some later today Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 29, 2016 Author Share Posted May 29, 2016 The nearside mount is the mount off the 2.5na reused but mounted in the rear set of mounting holes. The old 300tdi mounts need cut just before the rear set of holes so it can be used as supports for the bottom of the flywheel housing. I had to trim a small piece of the housing to allow for the slave cylinder too. Quote Link to comment Share on other sites More sharing options...
twodoorgaz Posted May 30, 2016 Share Posted May 30, 2016 Wow - that really is a nice job there - thanks for posting. I was picturing all sorts of weird angles twisting the mounts but they look good and solid. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 31, 2016 Author Share Posted May 31, 2016 Their actually very well made. I'm no racing snake so was unable to get a pic under the sump. There is a strengthening bracket at the bottom with spacers that uses 3 of the sump bolts. Quote Link to comment Share on other sites More sharing options...
