d1 trayback build
my disco has finally had it, all the seatbelt mounts have gone, its not going to go through another mot and the body shell is twisted where i smacked it in to a tree, sideways.
so i decided to do something fun with it... trayback it.
im going to let the pics do the talking mostly, but i'm making good progress, less than 3 full days into it now. im awaiting a steel delivery.
all pics are thumbnails, click to enlarge.
pic set one
pic set two
and as it sits atm...
getting on.
Progressing good, now comes the time consuming part! :) Loosing that overhang is really going to help its offroad capability, it is without a doubt the biggest hindrance when offroading any disco or RRC. Just make sure to add a lot of weight on there or it's gonna behave like a pig offroad. Sparewheel, fueltank, batteries, winch(es), Hi-Lift etc springs to mind. If you look at my Jeep cherokee build in this section you can see how far back I fitted everything to retain a decent balance in the car, but still it was quite nose heavy. And with a 101" WB they are somewhat comparable.
Also post up some specs on your Disco so we know what kind of beast it is! ;)
And most importantly, keep up the good work! :i-m_so_happy:
Its a mpi, so not exactly powerful but still a laugh.
at the moment its got a (half fitted..) 2" lift (body lift pending) 13000lb winch, sump guard, diff guards, welded rear diff (when i get round to it) insa turbo dakars, marine grade fuel tank and in line pump, and a load of steel to build a roll cage out of lol.
plans for the back include a winch (at some point) a lockable box to stick the recovery gear in, and of course the fuel tank, spare, high lift etc.
its gonna be fun :)
yeah im thinking theyre too hard, may get someone to wind me a pair custom.
the build is getting on now..
injury's to date
took corner of finger off on sharp edge whilst stripping bodywork
burn on left arm whilst welding up the back..... put torch down, lent across it to grab hammer. you can guess the rest.
burn on right hand whilst welding upside down (nahhh i wont bother with the glove for that 1" long weld...
and worst to date is the 2" long gash on a finger where i caught it on my angle grinder when i wasnt paying attention........ might have to get that one looked at in minor injurys tomorrow.... its not looking healthy.
these pics are 3 day old. havent taken todays.
Did you weld any flat bar or small gauge box across those flat panels? I know from experience that the drumming from flat panels drove me bonkers!!!
Looking really good there now.
You bending the cage up yourself or getting one made for you?
lust spent a hour or so examining that thread. thanks.
interesting way of doing the snorkle.
cage is nearly done, just need to finish welding it up, put the loops over the roof and put the second 'cross' in the hoop. then rip it off, paint it and stick it back on.
22/3/2014
26/03/2014
29/03/2014
  • 2 weeks later...
Great progress! I bet your looking forward to the first test in the dirt eh? :)
If you do get too annoyed from the lack of rear view, a mate of mine has a back up camera in his Rangie and it works just fine, should be a whole lot easier than fitting a window. (though probably a bit more expensive)
Lastly, I've made a little drawing for you :D Its just something that caught my eye, your cage would benefit hugely in strength if you fitted these two pieces of straight tubing:
Where you have those double kinks it is very likely to become flat if you put it on its rough, this would spread out some of that force to the rocksliders, just an advice, feel free to use it or not!
mmm i might do that. but not for a while. ive been working a full day then 5 or 6 hours on the truck for a month. i need to sleep now lol.
  • 2 weeks later...
