emcltd Posted April 19, 2014 Share Posted April 19, 2014 hi all I have a 2003 03 td5 es that won't start, key fob opens the central locking no probs, good battery all dash lights bright but won't turn over. replaced starter relay and a few fuses but no good, im sure it must be something simple, any help much appreciated before I have to pay the garage. thanks Quote Link to comment Share on other sites More sharing options...
dave88sw Posted April 19, 2014 Share Posted April 19, 2014 Could be the starter motor has failed? If you have a multimeter, check that you get a 12v feed to the small wire on the starter solenoid when the key is turned to crank. Otherwise, see if it will bump start, if so, at least you know it's not an immobiliser fault. Quote Link to comment Share on other sites More sharing options...
Disco DJ Posted April 23, 2014 Share Posted April 23, 2014 Does it just "click"? If so it could be the contacts in the starter motor gone, very common! (Mine did it!) Search "repairkitsuk" Quote Link to comment Share on other sites More sharing options...
emcltd Posted April 25, 2014 Author Share Posted April 25, 2014 starter it was thanks, wire had come loose Quote Link to comment Share on other sites More sharing options...
