boaterboy Posted October 22, 2014 Share Posted October 22, 2014 Hopefully, a simple request! Please could somebody provide me with a link to the section in the Land Rover manual showing the clutch hydraulic system (master cylinder, slave cylinder, etc.). Thank you, in anticipation. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted October 22, 2014 Share Posted October 22, 2014 http://www.landroverresource.com/docs/D2_Workshop_Manual.pdf PDF scroll bar number 457, or page number 33-2-2 to 33-2-5 It's your run of the mill clutch system hth (I just Googled it) Quote Link to comment Share on other sites More sharing options...
boaterboy Posted October 23, 2014 Author Share Posted October 23, 2014 I really appreciated your speedy reply, Shackleton. I see that your reference page nos. show a V8 arrangement. Is the TD5 the same? The reason I ask is that nothing is shown of the switch(s) which I understand are in the system to disengage the cruise control, if switched on, and/or cut the revs on changing up? Quote Link to comment Share on other sites More sharing options...
Shackleton Posted October 23, 2014 Share Posted October 23, 2014 Your guess is as good as mine. I would have thought so, and I'd say the switches/wiring will be on the electrical diagrams. You'll find that section of RAVE if you Google it. What is it you need to do? Quote Link to comment Share on other sites More sharing options...
boaterboy Posted October 25, 2014 Author Share Posted October 25, 2014 Good morning, Shackleton, I was trying to prove to someone who installed for me a new clutch master cylinder, slave cylinder and associated pipes that the switch in the system that activates the fuel cut-off (to reduce revs on changing gear) and disengages the cruise control (when depressing the clutch lever) had been missed off! This I have now done. Incidentally, on my vehicle there is no switch on the clutch lever (below the facia) which I understand was an alternative arrangement. Thank you for your help and ongoing interest. I appreciated it. Quote Link to comment Share on other sites More sharing options...
