whippet Posted April 24, 2015 Share Posted April 24, 2015 Hi looks like the slave has failed in my 02 freelancer td4 THE question is... is it essential to fit a new flywheel (money a bit tight) and is it as difficult as it sounds to drop the box and fit new clutch ect Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 24, 2015 Share Posted April 24, 2015 If only the slave has failed, then I see no need to replace the clutch unless you want to do it just because the gearbox is off. Les. Quote Link to comment Share on other sites More sharing options...
whippet Posted April 24, 2015 Author Share Posted April 24, 2015 Thanks les Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 24, 2015 Share Posted April 24, 2015 You have what is known as a concentric clutch - in that the thrust bearing and slave are one unit. These usually fail and leak into the bell housing, so leak onto the ground/master cylinder level dropping, are the usual signs. Book time on replacing the clutch is 7.3 hours, so expect twice that if you DIY it Les Quote Link to comment Share on other sites More sharing options...
L19MUD Posted May 21, 2015 Share Posted May 21, 2015 It is not a fun job Transfer box and whole front subframe have to come off First one I did took me two days. Could probably do in 10 hours now I have done one. Not for the faint hearted! Quote Link to comment Share on other sites More sharing options...
