BlueMonday Posted April 27, 2015 Share Posted April 27, 2015 Hi, Just put my Freelander through an MOT which failed on C02 emissions only! I took it back to the garage that fitted the CAT in November and they replaced it for a new one, it failed again on retest today They now think it could be the engine causing it....so i have just replaced the spark plugs to discover the old plugs weren't the platinum ones recommended for the freelander. It has been previously juddering/coughing when pushing the accelerator down quickly , but ok when pushed slower and kept in high revs, for fear of stalling. It seems to be alot more responsive now with the new plugs and having previously put some injector cleaner through it. Could the old non recommended spark plugs have caused the emissions failure? or could this be a different problem? I have uploaded MOT emissions sheet , for some advice. Many thanks Julie x Quote Link to comment Share on other sites More sharing options...
Jon White Posted April 29, 2015 Share Posted April 29, 2015 Lambda sensor would be the first thing I'd try. Quote Link to comment Share on other sites More sharing options...
rich broom Posted May 23, 2015 Share Posted May 23, 2015 carp old oil causes havoc on emmisions. Fresh oil and air filter for a start. Cheap cats are carp as well. Quote Link to comment Share on other sites More sharing options...
BlueMonday Posted July 16, 2015 Author Share Posted July 16, 2015 Thanks for replies, i am back with an update. Its turns out the CAT i had fitted was carp! Had it replaced with a approved one which was cheaper! Flew through the Test Still have a problem with the juddering...` She has had new plugs , leads, ignition coil, air filter, 3 mechanics scratching their heads, lambda sensor, temp sensors, injector cleaner The engine purrs like a kitten when idling, and not too bad if you don't press her too much, but as soon as you want her to work she keeps coughing and farting.... I am at a loss, it feels like a never ending nightmare. Since changing the ignition coil, she's not starting too well....any ideas? Many thanks Quote Link to comment Share on other sites More sharing options...
BlueMonday Posted July 16, 2015 Author Share Posted July 16, 2015 Positive update, Freelander is cured !! I am ashamed to say that the most basic thing was the problem.... Changed the distributor Cap and rotor arm...although in my defense i was told it didn't have this. No more juddering, pausing, loss of power....runs like a dream!! Thanks to my dad 1 Quote Link to comment Share on other sites More sharing options...
