CwazyWabbit Posted August 11, 2020 Share Posted August 11, 2020 Let me know how you get on with this. IIRC your speedo was in lovely condition. 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 11, 2020 Share Posted August 11, 2020 2 hours ago, CwazyWabbit said: Let me know how you get on with this. IIRC your speedo was in lovely condition. Will do. It always played up but I knew the connection at the transducer was a bit dodgy. When I looked at it last night I found one of the wires in the connector barely held in so changed the plug for a good one. Thought I had sorted my issue but obviously not! Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 13, 2020 Share Posted August 13, 2020 Not quite finished this but I had 12v at the connection at the dash end of the wire running to the transducer so there was certainly a problem with that wire. I decided to remove the original 3 core wire and run a new 2 core wire to take the live feed and signal. The earth has been terminated on the main earthing strap from the battery to the gearbox mounts. All I had time for at lunch so will connect those two wires up tonight at the dash end tonight and fingers crossed! 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 13, 2020 Share Posted August 13, 2020 Good news! Connected up at the dash end and working with no issues 2 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 15, 2020 Share Posted August 15, 2020 Phew! 2 Quote Link to comment Share on other sites More sharing options...
andy.cowman Posted yesterday at 11:34 AM Share Posted yesterday at 11:34 AM (edited) 4 years later..... i am now about to do this! It shouldn't be hard to see an improvement on my 200tdi as almost none of the panel of little bulbs work, the gauges are guesses at best! I managed to get some TD5 gauges which are in the post at the moment for £220. I think the only bit missing will be the plugs into the LED panel itself however you seem to be able to get the terminals on ebay for about £15 each now. So yeh - here goes some wiring next week! Edited yesterday at 11:35 AM by andy.cowman 1 Quote Link to comment Share on other sites More sharing options...
PaulMc Posted 18 hours ago Share Posted 18 hours ago 7 hours ago, andy.cowman said: 4 years later..... i am now about to do this! It shouldn't be hard to see an improvement on my 200tdi as almost none of the panel of little bulbs work, the gauges are guesses at best! I managed to get some TD5 gauges which are in the post at the moment for £220. I think the only bit missing will be the plugs into the LED panel itself however you seem to be able to get the terminals on ebay for about £15 each now. So yeh - here goes some wiring next week! Hi Andy, That's my listing on eBay 😀 I've posted the 2 x connector kits to you by RM Special Delivery. The connectors you've bought, mate with the TD5 instrument harness. The 16-way and 20-way connectors for the TD5 LED panel are here - https://www.ebay.co.uk/itm/151462720313 Regards, Paul. 1 Quote Link to comment Share on other sites More sharing options...
andy.cowman Posted 18 hours ago Share Posted 18 hours ago 27 minutes ago, PaulMc said: Hi Andy, That's my listing on eBay 😀 I've posted the 2 x connector kits to you by RM Special Delivery. The connectors you've bought, mate with the TD5 instrument harness. The 16-way and 20-way connectors for the TD5 LED panel are here - https://www.ebay.co.uk/itm/151462720313 Regards, Paul. Ah I will need them as well!! So did I only need one of the two I already ordered?! And do I just need one of the one I haven't ordered?! Thanks Andy Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted 18 hours ago Share Posted 18 hours ago @PaulMc do you do connectors for a lexis 1UZ ECU Regards Stephen Quote Link to comment Share on other sites More sharing options...
PaulMc Posted 17 hours ago Share Posted 17 hours ago 16 minutes ago, andy.cowman said: Ah I will need them as well!! So did I only need one of the two I already ordered?! And do I just need one of the one I haven't ordered?! Thanks Andy Yes, you only need one of the 14-way grey connectors. You also only need one of each of the black 16-way and 20-way connectors, which I sell as a set in my listing linked to above. If you want to return the second grey connector - that's fine, I'll refund you for it. 1 Quote Link to comment Share on other sites More sharing options...
andy.cowman Posted 17 hours ago Share Posted 17 hours ago 8 minutes ago, PaulMc said: Yes, you only need one of the 14-way grey connectors. You also only need one of each of the black 16-way and 20-way connectors, which I sell as a set in my listing linked to above. If you want to return the second grey connector - that's fine, I'll refund you for it. Yes please! Will send it straight back and have a word with myself for cocking it up already ! I have ordered the other one.... Thanks! Quote Link to comment Share on other sites More sharing options...
PaulMc Posted 17 hours ago Share Posted 17 hours ago 15 minutes ago, Stellaghost said: @PaulMc do you do connectors for a lexis 1UZ ECU Regards Stephen I don't have them - but I'm sure I could identify them. Looking on Google, there appears to be differences, depending on year of manufacture. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted 17 hours ago Share Posted 17 hours ago 9 minutes ago, PaulMc said: I don't have them - but I'm sure I could identify them. Looking on Google, there appears to be differences, depending on year of manufacture. I'll post some photo's tomorrow, thank you Regards Stephen Quote Link to comment Share on other sites More sharing options...
PaulMc Posted 16 hours ago Share Posted 16 hours ago 54 minutes ago, andy.cowman said: Yes please! Will send it straight back and have a word with myself for cocking it up already ! I have ordered the other one.... Thanks! Thanks for your additonal order, I'll get them in the post to you tomorrow. To return the spare grey connector, just send it back in the box, with the bubble wrap, I sent both of them to you in. My return address is on the rear of the box. Just stick a blank label over your address, the postage label, and the Special Delivery label, and use a 1st or 2nd class Large Letter stamp (they go-up in price (AGAIN!) by 15p, from 2nd April ☹️ ) Don't bother with eBay's return process, it's too complicated, more expensive than it needs to be, and can't cope with a partial return. Quote Link to comment Share on other sites More sharing options...
