chris2010 Posted November 26, 2014 Share Posted November 26, 2014 1988 . Lr90 90 front door seals ,? Have series door tops fitted.but tbh tops don't seal well atall . Any specials seals needed ,? So many to choose from Any help will be appriciated Quote Link to comment Share on other sites More sharing options...
paulnb57 Posted November 27, 2014 Share Posted November 27, 2014 I will be interested in the reply as to what other folk use, having standard 90 seals on mine with Series Doors and RM tops, it doesn't all quite fit, and its draughty(er) than normal..... Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 27, 2014 Share Posted November 27, 2014 Are they new door tops? New door tops are poop and don't fit properly. I modifiy mine by cutting almost all the way through the bolts with a thin disc, pulling them over to close the gap, then welding the bolts back up. If you look at new ones they stand up straight, whereas they should lean like the hardtop does. I have no trouble with mine sitting on the seals, and rock solid up to about 80mph, then they start flapping in the wind Quote Link to comment Share on other sites More sharing options...
chris2010 Posted November 27, 2014 Author Share Posted November 27, 2014 Are you talking about the where the bolts go through the door bottoms to bolt them together?. They are old door tops . Been like it since I bought the truck . Quote Link to comment Share on other sites More sharing options...
chris2010 Posted November 27, 2014 Author Share Posted November 27, 2014 Are they new door tops? New door tops are poop and don't fit properly. I modifiy mine by cutting almost all the way through the bolts with a thin disc, pulling them over to close the gap, then welding the bolts back up. If you look at new ones they stand up straight, whereas they should lean like the hardtop does. I have no trouble with mine sitting on the seals, and rock solid up to about 80mph, then they start flapping in the wind Are you talking about the where the bolts go through the door bottoms to bolt them together?.They are old door tops . Been like it since I bought the truck . Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 27, 2014 Share Posted November 27, 2014 That's right - check to make sure they lean in by the same amount as the hard top. Also, make sure the door is actually vertical, if the door bottom leans out, then the top won't fit correctly. This can be adjusted with shims under the hinges Quote Link to comment Share on other sites More sharing options...
chris2010 Posted November 27, 2014 Author Share Posted November 27, 2014 I will check in the morning . Thanks for the info Quote Link to comment Share on other sites More sharing options...
champlo Posted December 4, 2014 Share Posted December 4, 2014 looking into sealing the doors on my 110 as well, thanks for the info Quote Link to comment Share on other sites More sharing options...
zim Posted December 4, 2014 Share Posted December 4, 2014 Toyota engineers tested their door seals by putting a cat in the car on a Friday. If it suffocated over the weekend, the seal was OK. Landrover engineers used this, but changed the success criteria to whether the cat was still in the car or not! 1 Quote Link to comment Share on other sites More sharing options...
