Timing Strobe
stuck
Evening.
Can anyone recommend a quality timing strobe please?
The plastic Gunson one I have is great as long as you have either three hands or an elastic band to wrap around the pickup shoe :huh:
I don't need trick bits, just something that bloody works.
This is my understanding googling?
DIS - Distributor less Ignition System
Conv - Conventional
COP - Coil Over Plug - mini coil on cyl head
MSI - Multi Spark Ignition - fires more than once during ignition.
So Megasquirt/Megajolt with Ford EDIS is DIS? In theory this setting should negate the halving of the values, but as Snap-On charge for a manual there is not an online version to see if this is the case?
Marc.
