Paddy Posted June 16, 2014 Share Posted June 16, 2014 I have an ex military 2.5 na 90 which I added a homemade snorkel to, as a necessity not for looks. I need to make it more authentic and permanent. I saw an article that describe the military set up as through the near side, top of the wing, heater air intake and re routing the heater intake via flexi hose to a S111 heater air intake mounted on the n/s front wing. Anybody got any info. or seen this setup? I’m wondering how to ‘join’ the heater box to the flexi hose and what size hose is needed to match the S111 intake grill. This is the only picture I could find to illustrate the setup. Regards. Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2014 Share Posted June 16, 2014 Try EMLRA http://www.emlra.org/ some of their members should be able to help. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 17, 2014 Share Posted June 17, 2014 Let us know the outcome! Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 17, 2014 Share Posted June 17, 2014 I've seen it first hand, the royal marines used it in their waterproofed 110's. The plastic heater tray/box in the wing is deleted and the metal plate pipe is mirrored under the wing with a 90degress bend to go towards the air fiilter. pushed into the side of the underneath metal pipe section is a collection of 6mm tubes to carry the breathers from axles, gearboxes and engine timing cover. The heater hose is re-joined to the heater box using a flexi/rigid pipe and jubilee clips from memory. Quote Link to comment Share on other sites More sharing options...
Paddy Posted June 18, 2014 Author Share Posted June 18, 2014 It’s the replacement heater air intake that I’m having trouble get info. on, as in the size and run of the flexi, joining to original heater box and joining to the S111 air intake. Also seems very tight to run a flexi through. Posted on EMLRA so awaiting any feedback. Quote Link to comment Share on other sites More sharing options...
Paddy Posted June 25, 2014 Author Share Posted June 25, 2014 Let us know the outcome! Well EMLRA wasn’t a lot of help. Best info. I came up with is in the link below. The simplest for a diy job is on the Blue Defender. If you’re thinking of buying the whole job piece by piece then sit down before you browse !!! http://www.landyzone.co.uk/lz/f7/riased-air-intake-2-5-petrol-171100.html Quote Link to comment Share on other sites More sharing options...
Lewis Posted June 28, 2014 Share Posted June 28, 2014 There's one for sale on eBay at the moment http://www.ebay.co.uk/itm/131223574804 Quote Link to comment Share on other sites More sharing options...
Paddy Posted June 28, 2014 Author Share Posted June 28, 2014 It’ll be interesting to see what it goes for, mad rush in the closing few minutes!!Still left with the unanswered problem of what and how to do the heater intake. I’ve been running mine without a fresh air intake scoop and while I haven’t gassed myself I do get ‘engine smells’ which is this reason for wanting a better setup. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted June 28, 2014 Share Posted June 28, 2014 They don't look all that hard to fabricate.. Quote Link to comment Share on other sites More sharing options...
Paddy Posted June 28, 2014 Author Share Posted June 28, 2014 The snorkel is easy enough to get fabbed up, I have all the measurements. It’s the heater air intake that's the problem, no info. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 30, 2014 Share Posted June 30, 2014 The green 90 with the sankey you linked to earlier I know. The heater intake is a Series 3 grill fitted at the front with flexi tube run inside. IIRC this one uses tumble dryer hose. Quote Link to comment Share on other sites More sharing options...
unionjak Posted October 25, 2014 Share Posted October 25, 2014 Hello, i used rebel 4x4 for my ffr 110 exmod. It was a bit of a pickle as we had to cut a hole for the steel and loosen off the heater blower and do a lot of wiggling. Good piece of kit and works a treat. steve Quote Link to comment Share on other sites More sharing options...
Paddy Posted November 16, 2014 Author Share Posted November 16, 2014 Meant to update a while ago when I completed the alteration, see OP. Decided this was the easiest route to take. The radio box (whatever it’s called) was moved from the nearside to the offside, this left holes in the nearside wing top. Blanking plate cut to disguise holes and hole cut to take the new pipe work elbow. Rubber elbow (sort of like a 90 degree S shape) connects the pipe to the air filter box. All nice and water tight. Water still rising so will get a good testing in the next day or so pic2. Quote Link to comment Share on other sites More sharing options...
