mike4444244 Posted October 24, 2014 Share Posted October 24, 2014 Hi all, My TD5 110 is doing a budgie impression when switching off, at 155k miles I'm suspecting the damper, when pricing up it appears to be no longer available from LR? The britpart one is listed at £380, and allmakes at £700+ (!) From previous threads I was expecting about £380 for a genuine one so has BP taken over supplying oem ones? At £750 I'll let it pop and put a low mileage disco engine in! Mike Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 25, 2014 Share Posted October 25, 2014 Some on ebay at £170 ? Might be worth a try at that price ? And this is supposed to be OE ... http://pages.ebay.com/link/?nav=item.view&alt=web&id=201089380816 Quote Link to comment Share on other sites More sharing options...
Shackleton Posted October 25, 2014 Share Posted October 25, 2014 Have you spoken to LR? Sounds strange Whatever happens, don't buy the spurious one. I did, despite a 50/50 mix of advice from people for/against it where quality was concerned. The against people were right. Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 25, 2014 Share Posted October 25, 2014 I had a look on turners website knowing that they don't sell tat. Their damper is britpart and in brackets they state that it is the 'only available option'. I'd give Frida a ring and see what they reckon to them - at least you'll get an honest opinion, but it looks like it might be the only option. http://www.turnerengineering.co.uk/acatalog/TD5.html Island 4x4 also have britpart ones at 199 plus vat. 1 Quote Link to comment Share on other sites More sharing options...
Shackleton Posted October 25, 2014 Share Posted October 25, 2014 Oh no. hey don't forget to get a front crank oil seal while you're at it. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted October 25, 2014 Author Share Posted October 25, 2014 Hmm I suppose I'll have to hope that the carp one might last me a while given I don't do a huge mileage Thanks guys Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted October 25, 2014 Share Posted October 25, 2014 Mike, Are you confident it's not the belt slipping and chirping. Mines been doing the same since the last belt / tensioner change. Neil Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted October 25, 2014 Author Share Posted October 25, 2014 Hmm haven't investigated the belt too closely, I just assumed the chirp was the pulley, it's only on switching off the engine and it's been getting worse, the belt is relatively new since I fitted my air con compressor, I'll investigate a bit more thoroughly in daylight tomorrow! Mike Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted October 26, 2014 Share Posted October 26, 2014 When I changed the belt to a lesser known brand I had a lot of squealing. Switched to Dayco and reduced to a chirp when shutting down. Try switching air con on and run the engine for a while, switching off while the compressor is engaged. Chirp likely to be louder. Try staring the engine while compressor is engaged. Does it squeal ? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted October 26, 2014 Share Posted October 26, 2014 I've started glueing the td5 pulleys together with tigerseal which seems to make them last longer than 1 event Quote Link to comment Share on other sites More sharing options...
