Caravan Conversion
2003Freebie
Why not!
It could be quite cool. With all the seating removed, there is certainly (just) enough space. Put Gas & Batteries under the bonnet.
I would add a fair bit more insulation than standard otherwise it will be very cold in the winter - and probably block off the rear & rear side windows, again for insulation.
If the front A-Frame & hitch were removable, you could park up (and sleep in it) anywhere - which is a big plus!
I hope to see how it progresses.
Si
