whippet Posted July 23, 2014 Share Posted July 23, 2014 i have a 02 td4 the front o/s and n/s and rear n/s windows have stopped working also the o/s rear is iffy some times will sometimes wont work im thinking window relay any thoughts from you good fellows, and where is it situated thanks in advance Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 24, 2014 Share Posted July 24, 2014 There's a full wiring diagram in the RAVE manuals, I'm not aware of one relay that controls them all so seems a bit unlikely. Quote Link to comment Share on other sites More sharing options...
whippet Posted July 24, 2014 Author Share Posted July 24, 2014 i think your right FF i took the panel off drivers side removed the reg had a play with it, separated the motor from it. and the motor would not run when wired to battery. i just kept turning the motor with my fingers and all of a sudden away it, went put it all back together replaced reg into door and its working again although it does stick at the bottom give door a bang and up it goes. wonder if i have the window in correctly it doesn't always stick again FF thanks for the help.......... next problem front wipers will not park any thoughts Quote Link to comment Share on other sites More sharing options...
whippet Posted July 26, 2014 Author Share Posted July 26, 2014 took the passenger side door panel off to day to try and sort the regulator put the meter on the motor. power to go up but non for down tried swapping the switch for the drivers side still up only the motor is ok it runs both ways when just connected to battery Quote Link to comment Share on other sites More sharing options...
