piston oil spray jet
  • Please log in to reply
8 replies to this topic
#1 heggedear
heggedear
    Newbie
  • New Faces
  • Pip
  • 3 posts
Posted 23 January 2007 - 09:07 AM
Hello from Germany. My problem is this. When i renenew the sump gasket of an 2.5 n/a diesel engine (LDV) i found the broken tube of a piston oil spray jet down in the sump. is it possible to fit a new one without taking the crankshaft out ?? . without the tube has the piston enough oil to do his job nice ? For any help i would say Dankeschön
#2 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,153 posts
  • Location:Third rock from the Antarctic - 51°41.8'S 57°50.5'W
Posted 23 January 2007 - 03:01 PM
Welcome :)
I don't know the answer to your problem, except that it probably does need the jet, but welcome anyway!
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#3 western
western
    Recovery Man
  • Moderators
  • 31,232 posts
Posted 23 January 2007 - 06:37 PM
Defender workshop manual says fit the oil jets then refit the crankshaft, but it maybe possible to change the oil jet without stripping the complete engine, remove the sump & have a look, I think you soon see which way to proceed.
extract fom manual [ignore the right hand column]
Posted Image
hope it helps & welcome to LR4x4.com :i-m_so_happy:
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#4 Phil Hancock
Phil Hancock
    Old Hand
  • Settled In
  • PipPipPip
  • 1,389 posts
Posted 23 January 2007 - 07:52 PM
Posted Image
It will be tight to get at with the crank in, but having a look will soon show if it possible with the tools you have. Yes they are very important, as they provide a jet of oil for cooling to the piston crown that can lead to siezing/nipping of the piston in the bore if its not there. Been there, seen it, done it!!
#5 heggedear
heggedear
    Newbie
  • New Faces
  • Pip
  • 3 posts
Posted 23 January 2007 - 08:14 PM
Thank you for your help, i don`t know since when the spray jet is broken. Next week i will do the sump again, and see how i can do it . But the next work is waiting. The seals (t-style) of the main bearing cap and the crankshaft oil seal are ready to change. I think to put the whole engine out and make a general overhaul. Danke from Germany.
#6 Les Henson
Les Henson
    Still waiting to weld my new chassis :(
  • Supporters
  • 12,938 posts
Posted 28 April 2008 - 07:27 AM
I forgot to fit mine before fitting the crank in my 300TDi engine, so had to put them on afterwards. It is fiddly, but do-able. They are important though - they cool the underside of the piston crown and lubricate the bore and small end bearing.
It can't have been off for long or there would be some damage fairly quickly.
Les.
Keep this forum independent click here.
#7 silvio
silvio
    Member
  • Settled In
  • PipPip
  • 115 posts
Posted 28 April 2008 - 01:15 PM
If I remember correctly, they are "handed", so there are two kinds of jets, one bent to the right and another one bent to the left.
Either you buy one of each kind, or you'll have to remove the sump and see which one is missing, before buying the replacement.
Remeber to buy the copper seals, as well, as they are of a collapsible kind, not easy to find outside of LR spare parts.
#8 Les Henson
Les Henson
  • Supporters
  • 12,938 posts
Posted 28 April 2008 - 02:46 PM
Silvio is correct - there are two different ones and they are not interchangeable. They have locating pegs that hold them at the correct angle.
Attached File  engine_rebuild_013.jpg   185.62KB   10 downloads
Les.
#9 western
western
    Recovery Man
  • Moderators
  • 31,232 posts
Posted 28 April 2008 - 05:49 PM
Piston cooling jets as fitted in a LR 2.5n/a diesel
ETC6531 x 2 number 1 & number 3 pistons
ETC6532 x 2 number 2 & number 4 pistons.
