200 tdi crank damper and pully
  • Please log in to reply
12 replies to this topic
#1 selectcase
selectcase
    Member
  • Settled In
  • PipPip
  • 190 posts
Posted 03 April 2007 - 12:23 PM
I am about to reassemble the cambelt, pullys etc. The crank *& keyways are in good condition and i was wandering what you guys do about assembling the crank pully & damper together. Do you use anti sieze assembly so they are not such a bugger to get off the next time or loctite to stop them coming loose? I know you use loctite on the crank bolt threads.
cheers
will
#2 nickm
nickm
    Old Hand
  • Settled In
  • PipPipPip
  • 344 posts
Posted 03 April 2007 - 12:28 PM
sorry but can i add a question
what sort of ummmppphh do i need to do the tensioner upto
my 200's also in lots of bits awaiting re-assembly
#3 Muck Truck
Muck Truck
    Member
  • Settled In
  • PipPip
  • 28 posts
Posted 03 April 2007 - 12:38 PM
a lot :lol: cant remember off the top of my head but its up somewhere like 280 Nm (for a 200 tdi)
when i did mine i was slipping the clutch so couldnt get it any tighter, but today ive just got one of these from ebay crank locking tool
so i can now re-tighten my crank (200 tdi) and do the Disco 300 Tdi cambelt we've got.
edit.
i am on about the damper bolt, not the belt tensioner, quoted wrong post here.
#4 Lars L
Lars L
    Old Hand
  • Supporters
  • 806 posts
Posted 03 April 2007 - 12:48 PM
Tension on the square hole for the cambelt tensioner should be 18-20 Nm. At least on a Disco engine, I might add... Done that today, see. ;)
1997 Defender 110
1958 SII 88 diesel
#5 nickm
nickm
    Old Hand
  • Settled In
  • PipPipPip
  • 344 posts
Posted 03 April 2007 - 02:08 PM
ta
thats my bit sorted
#6 stripy
stripy
    Old Hand
  • Settled In
  • PipPipPip
  • 271 posts
Posted 03 April 2007 - 03:27 PM
yes put loctite on the pully & the shaft & keyway
i wish i had all the toys!!
#7 Les Henson
Les Henson
    Still waiting to weld my new chassis :(
  • Supporters
  • 12,932 posts
Posted 03 April 2007 - 03:57 PM
Pulley/damper bolts are 4 x M8 coarse bolts, use a small amount of any thread locking compound as these bolts don't usually work loose. Timing belt tensioner I set at 20nm.
Setting the tensioner 'until the clutch slips' will see the belt snapped/timing case wrecked/or similar, (bit of confusion going on here I think ) :)
Les.
Keep this forum independent click here.
#8 Red90
Red90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,883 posts
Posted 03 April 2007 - 04:28 PM
Les.
He was referring to the large bolt holding the dampener onto the crankshaft.
#9 Muck Truck
Muck Truck
    Member
  • Settled In
  • PipPip
  • 28 posts
Posted 03 April 2007 - 04:41 PM
Les.
I quoted wrong post there :rolleyes: but cause im new and posts are still moderated, i couldnt edit it when i realised id done it wrong
#10 Les Henson
Les Henson
  • Supporters
  • 12,932 posts
Posted 03 April 2007 - 04:47 PM
That statement wasn't describing the crank bolt to me, hence my reply. Tensioner remark was tongue in cheek, hence the presence of the smiley :)
Les.
#11 selectcase
selectcase
    Member
  • Settled In
  • PipPip
  • 190 posts
Posted 03 April 2007 - 07:47 PM
Sorry - I may have caused some confusion here, what i am talking about are the crankshaft cog for driving the cambelt and the pully damper - they both slide on the crank shaft and locate via the 2 woodruf keys.
As they are frequently siezed on the crank when attempting to change a cambelt requiring a puller to get them off the shaft I was thinking of using a little antisieze compound but they appear to have been assembled on the shaft with loctite.
I am using new woodruf keys, new crank cog etc so everything is squeaky clean - hope that clarifies it :)
#12 western
western
    Recovery Man
  • Moderators
  • 31,147 posts
Posted 03 April 2007 - 07:57 PM
Genuine manual says fit the crank pulley [no mention of any substances between it & crankshaft] & fit damper using loctite 242 on the crank bolt threads only before torquing the bolt up.
I've never used anything on the crank for these 2 parts not had any problem removing them at timing belt change time.
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#13 Les Henson
Les Henson
  • Supporters
  • 12,932 posts
Posted 04 April 2007 - 01:44 AM
Just lightly lubricate the nose of the crank with engine oil or light grease, then assemble as per Ralphs reply.
Les.
