I just drove one!!!!
Guest deleted
Guest diesel_jim
I just drove past my dealers and they had a new '07 90 hard top on the forcourt, so i popped in and said "Gis' the keys then", and they did.
so i took it for a 10 mile or so rant the t!ts off of it gentle appraisal drive....
Well, i think i'll stick to my Td5!
engine, very nice, similar torque to the Td5 (although i'm comparing it to my 110 SW which is considerable heavier than a 90 HT), but performance seems very similar to 90 Td5's i've driven. interior noise is very slightly less than the Td5, but not much.
6 speed box is loverly. hopefully one day Sir Ashcroft will come up with a suitable bellhousing to mate that box up to a Td5 or the 2.8 international (now that would be a nice combination!)
i crawled underneath it and took some pics, the transfer box looks to still be tha LT230
but that dashboard! smilie_barf.gif In the magazines it looks good, yes, but when you sit in it, it "overpowers" you. If it was about 6 or 8" further "forward" away from you, it would be OK, but the middle bit looks like a pregnant womans belly poking you in the face.
when i was sat in it, (and i'm 6'5") my left knee was constantly touching the corner of it, and i couldn't slope forward to get my mobile out of my LH pocket, there wasn't enough room to move forward.
heater is good, speedo and rev counter layout is good.
hi-lo lever is too far down and poking back (same layout as the current defender, hi-neutral-lo difflock etc) but you can't see the top of the gearstick. OK if you're used to defenders and know where the positions are, but pants for anyone else.
and that bulge on the bonnet! 1-picture3.gif LR really should have put their foot down with Ford and made them re-engineer the top of the engine to make it lower, it's a real eyesore (plus you lose the space for a spare wheel)
the front doors have been changed too, instead of welded "C" section where the glass winds up into, it's a rolled piece of steel now, looks rather like the Santana doors.
Front wings no longer have the galvanised inner bits... it's plastic now.
And the engine ECU is now under the bonnet, bolted to the bulkhead....banghead.gif what a clever idea that was........pel6.gif
Sooo, like i said, i think i'll stick to a Td5 with the earlier dash, and would love the 6 speed box mated to it!!
Pics:
Lack of knee room:
Dash waaay too far forward...
Dash panel under "old type" steering shroud... room to lose stuff!
new type doors
BIG dash
Various engine pics
new heater
cup holder?
air filter and MAF
closed up of rocker cover mounted cup holder.
nice place to mount the ECU!
underside of bonnet bulge
sump of engine
Hope they carry plenty of spare silencers in stock... and the thing is HUGE, you could live in it!
brand new!
LR build quality.... bolts in view and trim not fitting properly behind gearstick
(carp photo) but daylight showing through passenger footwell at corner of door!
Guest diesel_jim
Good write up Jim,,
But the door tops have been like that since 05 model year ! ??
Have they? D'OH! :rolleyes: I think the last one i drove was an '06 double cab as a loan car, and that had the older doors fitted (obviously a pile LR had kicking about?)....i didn't realise the earlier cars had these type.
Interesting :)
First impressions: far too much plumbing in the engine bay and whoever put that ECU there should be shot (its the first underbonnet pic I have seen and you know what I do for a living!)
New doors came in with 05 I think, my 04 90 doesn't have them but the new ones here have had for a while - they don't stop any more water though :rolleyes:
Time is running out to get myself a nice 300Tdi 110 before the last ones disappear here :unsure: still no takers for the 90 though :angry:
Can't believe that on a dealer demo car they forget to fill up the holes in the corner of the doors (or indeed that the problem STILL hasn't been fixed) :rolleyes:
What is the throttle response like - does it do what the pedal says (like most cars) or does it do what the dark forces of Evil lurking under the seat feel like doing which may or may not conform with the driver's requirements at that point in time (like a Td5)?
Guest diesel_jim
Interesting :)
Seemed almost identical to a Td5 Stephen. same "nearly a second pause for thought" before the engine actually revs up (like the anti-shunt on the Td5's), same amount of physical pedal travel, and in low box, same amount of "low rev" travel up until the last 1/64th of an inch where it revs the t!ts off of it. :rolleyes:
The intercooler looked identical to a Td5, as did the radiator.
like you say, very "busy" under the bonnet.
That ECU mount is classic and the dash does make the front interior appear even smaller. Reading the test in this month's LRM you are left with the impression that the reduction in interior noise is vast but obviously not so. When I was looking to chop my last Defender in I considered waiting for the new model but decided against until it's been tested by some real world users - handy pics Jim :)
"30% quieter than a Td5"
The Decibel scale is exponential, so 30% is easily reached... I believe that it should be about 3 or 4 dB quieter to attain that 30%
Either that or the teste was deaf from driving Defenders in a previousl lifetime...
our td5s 05 and 06 have those door tops, T box is the same one LT230 but with the Q gears i believe.
Did you get it over 82mph (its limited! although can be testbook over ridden)
i am looking fwd to comparing one to my chipped (360Nm) overdrived td5, should be the same to drive but with better heater then!
Guest diesel_jim
Is the gearbox tunnel still offset to the left side? Some of the promotional photos made it look like it was centered. For LHD models, the offset has always been a huge PITA as there is not enough room on the left side.
I didn't notice it to be offset at all, felt the same as the R380 does in my 110
  • 2 weeks later...
Guest diesel_jim
I called in to my local main dealer on the off chance the other day and they only had TD5's in the showroom, the new one was remarkable by it's absence.
Same as that, my dealer hasn't got one in either, no big banners stating "new defender etc", nothing, nada.... you'd have thought that they would try and push it a bit!
on the same lines... anyone seen that advert for the Nissan range of vehicles? cool or what! where they change into animals and crawl/climb/swim over the terrain.
good thinking there, thats the sort of thing LR should be doing, instead of some pompus (although admitadly rather attractive) member of the royals.
3dB in (electrical) power terms is 50%.....
