However.....
Having driven it for a while I notice that there seems to be a bit of vibration from something at low speeds under load. I first noticed it when I was towing a broken down 110, and pulling away in first gear with the 110 on a rope behind there was quite a noticable judder. It's less obvious with nothing tied to the back and pretty much disappears once you get a bit of speed up.
What are the normal symptoms of propshaft vibration? I've never suffered from the problem before and as I've said before the old 90 had "90 rear" springs on the front and didn't do it - though those were second hand ones and these are new (so possibly sit a little higher), also these have the ANR2938 isolator rings on top. Does the prop normally vibrate at low speed, or high, when the operating angle of the UJ's is a little too much? The obvious culprit is something to do with the suspension being higher as it wasn't doing it before.
Any experience of lift-related vibrations would be appreciated
I hope that if this is the problem I might be able to get away with just taking the isolator rings out - they are about 0.3" thick so will reduce the height by about that much, might be just enough to stop the vibration?
So much for only having to take all the front shockers and stuff off once - famous last words
Oh well if they have to go in the bin at least the springs were free, glad I didn't have to buy them
a shame as everything else about the lift is fine, just about what I wanted, but I am not prepared to go to the expense of double cardan props, I'd rather lose half an inch at the front
