LR4x4 - The Land Rover Forum: Drop arm ball joint change insitu - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Drop arm ball joint change insitu By Les Henson
#1 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 15 May 2007 - 07:27 AM
As it's quite common for the drop arm to refuse to budge, it's fairly common to have to replace the ball joint from under the vehicle while the arm is still fixed to the steering box. Any L/R that has this type of joint has the same method of repair. The vehicle in this thread is a 1996 110CSW. The vehicle failed the MOT on excessive play in the joint, and nearly always this is attributed to the boot splitting and letting the grease out and water in. The subsequent rapid corrosion quickly wears the joint away, causing vague steering and wandering.
Raise and support the drivers side front of the vehicle.
Posted Image
If you have the castellated nut type - remove the split pin.
If you have a nylock nut, then a 19mm spanner or socket.
Posted Image
Strike the housing a few times and the joint will pop apart. Pull the link rod/steering damper down and away.
Posted Image
Posted Image
Remove the split rubber boot and you will see the problem.
Posted Image
A circlip holds the innards, spray some WD40 or similar over it, tap each eye of the clip to loosten it, then remove the clip with a pair of circlip pliers
Posted Image
Posted Image
Posted Image
Once the circlip is off, the guts of the ball joint will come out. This is normally what you see.
Posted Image
The top cup is still inside the housing, and is usually quite difficult to get out.
Posted Image
Posted Image
Use a small wire brush to clean the inside, and this is the method I used. A 14mm socket fits just nicely in the top and is just a bit smaller in diameter to the cup. A strong G-clamp and something to spread the load/protect the arm. By alternately tightening the clamp and hitting the bottom of the clamp with a hammer, slowly draws the cup out.
You must keep it all in line or the cup will bind in the housing and then becomes more difficult to remove.
Posted Image
Posted Image
The remains of the old joint.
Posted Image
The new ball joint kit.
Posted Image
Clean the inside of the housing and use almost the same method to fit the new cup. The socket size is bigger though - 20mm. Put a smear of grease around the inside of the housing and also around the lip of the new cup, then press it in as shown. Again make sure the socket stays nice and square.
Posted Image
The new cup in place. Check from the top to make sure it's all the way in.
Posted Image
Posted Image
Dunk the ball end of the joint in some grease, put it up from the bottom and keep it in place with a cable tie or a similar method.
Posted Image
Posted Image
Bottom cup next - a small amount of grease will stick it to the bottom of the ball.
Posted Image
Add a small amount of grease to the bottom of the cup, then stick the spring with the thinnest part downwards, then the thin O-ring, and then the bottom plate - this may have just one chamfered edge, and this should be on the inside.
Posted Image
Posted Image
Posted Image
The bottom plate needs to be pressed inside the housing far enough to put the circlip on. I use a jack, extension bar, and socket to do this. Note that if you use a thicker bar, the circlip will have to be put on it before the jack is raised.
Posted Image
Make sure that the plate is pushed in evenly and then fit the new circlip - making sure it's in the groove all the way round (tap it in all the way round to make sure)
Posted Image
Posted Image
To the top now, fill the gap with grease, then put the new boot on and secure it around the bottom.
Posted Image
Posted Image
Fit the smaller ring to the top of the boot, this is a right fiddly swine of a job.
Posted Image
Put the steering rod back on, washer, castellated nut, and then secure with a split pin (or just tighten the nylock nut.
Posted Image
Les.
Tony
Keep this forum independent click HERE.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
