LR4x4 - The Land Rover Forum: Replacing an LT230 Transfer box - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Replacing an LT230 Transfer box By Les Henson
#1 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 25 May 2007 - 06:33 PM
The following thread is the replacement of the LT230 Transfer box as fitted to a 300TDi engine in a tricked-up 90. The method of replacing any transfer box is much the same - regardless of engine or vehicle (not sure about a Freelander though). These units are very heavy and awkward to manhandle, so it would be easier to have a second pair of hands available when lifting it off and replacing it. The box in this thread is brand new, so if you are doing the same, then the diff lock switch and speedo drive will have to be swapped over onto the new unit. The replacement transfer box is a 1.410 ratio unit and is replacing the 1.222 that was on the vehicle originally. If you don't already have the cross-drilled input gear fitted, then the relatively small cost of one makes it worthwhile to replace at the same time.
Park the vehicle on level ground, chock one or both rear wheels, jack up and support the front of the vehicle. Once both props are off you will have no gearbox or handbrake lock on the wheels.
The transfer case, and its position under the vehicle. Front and then rear view:-
Posted Image
Posted Image
First drain the transfer case - 17mm socket or spanner to remove it. There is an internal magnet that is put there to scare those that don't know better :D. It's quite normal to have a fine paste of steel on the magnet, but this one was surprisingly clean.
Posted Image
Posted Image
Posted Image
Ratio identifying label (the filler/level plug is above and to the left)
Posted Image
Using a propshaft nut tool, remove bothe the front and rear props.
Posted Image
The prop nuts are supposed to be held captive, but in reality just turn, so you will probably have to use a 14mm spanner as well.
Posted Image
Once the rear prop is off, there's a 30mm nut that has to be loosened. Apply the handbrake hard, and use a breaker bar or similar leverage to undo it.
Posted Image
Posted Image
Then undo the cross head screw that holds the handbrake drum in place. ( you may have tio use an impact driver to do this)
Posted Image
Remove all tension in the handbrake cable - use a 19mm spanner to undo the adjuster nut (there's one inside the bracket as well, which may turn as too, so you may need to use two 19mm spanners).
Posted Image
Posted Image
On the opposite side of the handbrake backplate there's an udjuster. Using an 11mm (7/16" spanner) - undo it until it no longer clicks over every 90 deg of a turn.
Posted Image
The handbrake drum will now lift away, and this is what you should now be looking at.
Posted Image
Remove the 30mm drive flange nut and remove the nut, washer, and drive flange.
Posted Image
With the flange out of the way you can now see the output shaft oil seal, and the 4 x 17mm head bolts that hold the backplate to the transfer case - remove them.
Posted Image
Remove the split pin form the linkage closest to the backplate.
Posted Image
The backplate, complete with the shoes, expander unit, etc, will now lift off.
Posted Image
Handbrake cable support bracket next - there should be two bolts in here for this type of bracket. Remove the two at the front, and then two at the side (13mm socket/spanner)
Posted Image
Posted Image
The bracket and cab;e can then be tucked away on top of the chassis rail.
Posted Image
Disconnect the feed to the diff lock switch.
Posted Image
Speedo cable next - this is retained by a forked bracket and a 10mm nut on a stud. The stud may come undone, but it doesn't matter.
Posted Image
You now need to remove the input gear, which involves removing the rear cover and bearing track carrier.
Remove the 6 x 17mm bolts (note ine should have a handbrake cable support bracket/clip on - they are normally brocken, but you can use the bracket with a cable tie to do the same job). You may also have an Earth cable attached to one of the bolts, as in this picture.
Posted Image
With the cover plate off - you can see the bearing track carrier. Early 90/110's will have a couple of big cross-head screw holding the carrier in place, these will have to be removed.
Posted Image
The carrier, and the input shaft gear still in position
Posted Image
You will notice the red paste around the input shaft where it comes through the gear. This is an early sign of premature wear of the two due to poor lubrication. A cross-drilled gear will cure this problem.
Posted Image
With a bit of careful wiggling of the gear and associated gears, it will come out of the transfer case.
Posted Image
The input shaft - check the condition of the splines for wear.
Posted Image
Slacken the 15mm nuts that hold both gearbox mounts to the chassis mounts - do not remove them.
Posted Image
Posted Image
There is one mount on the gearbox and one mount on the transfer case - bend back the locking tabs and remove the 4 x 19mm head bolts that holds the mount to the transfer case (drivers side)
Posted Image
From inside the vehicle, remove the drivers seat cushion, drivers floor panel, transmission tunnel cover, and centre seat/cubby box panel.
Posted Image
Posted Image
Posted Image
Undo the 13mm nylock nut that holds the diff lock plate to it's shaft - note that there atwo flats on the base of the shaft. Not the position of the plate - it must go back on the replacement box in the same position.
Posted Image
Posted Image
High/low range lever next - again 13mm nut and a bit fiddly to undo. Just the lower one to preserve the position of the linkage. If you have to slacken the upper nut, then count the turns and make sure it goes back the same way.
Posted Image
Posted Image
The breather pipe next - it's 15mm, and the banjo bolt should have a copper washer eother side of the pipe fitting.
Note also the diff lock switch earth wire - 11mm socket to remove the bolt, and the short cable will come off.
Posted Image
Posted Image
All that's now holding the transfer case to the rest of the vehicle are the 6-bolts that secure it to the gearbox. 5-of them are 17mm head, and one is 13mm. Remove the one to the left of the transfer case (at 10-oclock), just slacken the one to the right of it, but leave it in place and just finger tight. Following the line of the transfer/gearbox line, remove the rest.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The 13mm bolt - you can get at it with a 13mm socket on a 10-inch wobble bar.
Posted Image
Now place a jack under the gearbox and raise it until you have a small gap between the mounts and the casing.
Posted Image
Get in a position where you can move the transfer box back and off the gearbox shaft, then onto the ground. Take the weight of the Transfer box abnd remove the final bolt.
Posted Image
Some kind of cushion, such as a pad of cardboard or wood to drop the box onto as soon as possible. These things are unbalanced and awkward to control.
Posted Image
The new box, bone dry of oil, and large amounts of various types of packing tape/Denso tape, and cardboard.
Posted Image
Posted Image
There's a loacting dowel on the new transfer case - make sure that the old one hasn't been left in the gearbox, or the two will never fit together.
Posted Image
Clean the gearbox shaft, and lightly grease it. If there's any sign of oil leaking past the seal, then replace that too.
Posted Image
Lift the new transfer case into place, taking care not to damage either seals as you go. Hold the case in place and hand tighten a couple of the bolts. Once a couple are in, you can then fit the rest and tighten them.
Posted Image
If there is no speedo drive, then carefully lever the one out of your old box, clean and grease it, then press it into the new box after apllying some grease to the hole of the new housing.
Posted Image
The two components of the speedo drive.
Posted Image
Posted Image
Posted Image
Make sure the speedo inner cable goes in the centre of the drive like this.
Posted Image
And secure the same as on the old box. Don't do the 10mm nut up too tight - it only needs to hold the outer cable.
Posted Image
That's about it really, put it back together the same way you took it all apart. Fill the transfer case with fresh EP80/90 oil. and keep an eye on things for a while to make sure everything is ok/you didn't forget to tighten something :D
Les. :)
Tony
Keep this forum independent click HERE.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
