Unimog Disc brake Conversion
  • Please log in to reply
14 replies to this topic
#1 mc4x4
mc4x4
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 19 June 2007 - 10:44 PM
I am interested to hear back fom anyone who has done a disc brake conversion on unimog 404 axles.
Pics would be fantastic, but any feedback would be great.
cheers Mark
#2 steve b
steve b
    Old Hand
  • Settled In
  • PipPipPip
  • 1,529 posts
Posted 20 June 2007 - 06:56 AM
Hi ,
Welcome to the forum mc4x4..
I had a chat with Dirtydiesel (on here) the other day about this & he converts to G-Wagen discs on 404's, Straightforward supplies also do a disc conv using RRC disc's . Not sure if portaltek do anything moggy - they are volvo c303 mainly. I think you'll find lots of info on Pirate as well , haven't been on there much myself.
Looking at it myself for the future. Did you get your axles in oz then? didn't realize 404's were imported to Australia....mind you saw plenty of army 404's in NZ when i was there a few years back.Attached File  DSCF0008.JPG   295.65KB   46 downloads Mmmmmm 404 mog
cheers
Steveb :P
portal - a doorway to a different world
#3 pugwash
pugwash
    Not getting muddy enough!
  • Settled In
  • PipPipPip
  • 2,267 posts
Posted 20 June 2007 - 07:50 AM
i'm spending quite a long time looking at the options for mog disc brakes and found the following:
1. Straight forward supplies (a uk based company who have brought quite a few new products to market for remarkably good value): Pros- cheap, uses discovery parts all round, quite quick to supply on an exchange basis. Cons: Built to a price, increases your trackwidth significantly, i'm not 100% of how their kit seals up against the labyrinth which could be an issue.
2. Dirtydiesel on here (does a lot of mog stuff and i wouldn't hesitate to recommend his work to anyone): Pros- will be very well made, uses G-wagon parts which means you can at least get wheels for it, he will do all the work for you, really quite reasonably priced and trackwidth is unaltered. Cons: You might need to send him your hubs (although check with him), no idea how complicated his conversion is so getting things fixed later if he stops doing the conversion might be hard
3. Tibus off road (a german/ US company who do a lot of 404 stuff like CTIS etc). Pros: uses brand new hubs (not remachined) and pretty sizeable rotors and calipers, retains the original PCD of the mog wheels, probably quite easy to ship from the US to you. Cons: I didn't get on with tibus when i phoned them (don't know why- just didn't like them), uses somme pretty odd parts (such as corvette calipers) which would be a little bit of a nightmare to get in the UK, not particularly resaonably priced and seemed to pluck a price out of thin air when i asked.
4. Exaxt (canadian supplier). Pros: Really really impressive looking kit, extremely well developed by the look of it and i would say very very well engineered. Probably the very best kit. Liked both of the chaps who run the place, they couldn't have been more helpful. Cons: Easily the most expensive- going to cost 2000 to get into the uk- whilst it seems likely that the price is fair for what they are supplying it's still a huge amount of cash, you have to use 16.5" rims and even then they "might" rub a tiny bit (this could limit your tyre options), they use ford F250 4x4 HD parts which i bet are nigh on impossible to find in the UK for any sensible sort of money.
5. Weps (on pirate 4x4) who only supplies machined rotors (although there is a chap on pirate who is also creating laser cust caliper mounts). Pros: Dirt cheap (really really dirt cheap), allows you to use whatever kit you want. Cons: There is A LOT of work for you to do, you have to send the hubs to the states, you may well be better off doing the whole conversion yourself.
i haven't found anyone else yet- portalteck only do 303 stuff (or kits for their own axles). of course you always haev the option of doing it yourself, which i don't think would be impossible, however for someone with my very limited engineering skills and experience (ie none) it would take me an age to get the kit designed so that everything lined up right, the parts were sourced right, etc etc (as ever it comes down to time/money, either you spent some money getting it done, or you spend some time doing it yourself- often for me the former is more profitable!)
Jim
Running around Confused
#4 king cj
king cj
    Member
  • Settled In
  • PipPip
  • 24 posts
Posted 20 June 2007 - 12:36 PM
ive got the tibus kit and it works well, chevy one ton discs and corvette calipers. gives alot of stoping power but needs a good mater cylinder. parts arnt difficult to get( usatomotive in bedfordshire has most of it on stock). think i paid 50 to repad both axles.
if big tyres are in your trucks future ie anything bigger than 37s this is a good kit to have.
#5 Astro_Al
Astro_Al
    Forum Rocket Scientist
  • Settled In
  • PipPipPip
  • 2,133 posts
Posted 20 June 2007 - 01:43 PM
Here's some info on the killeraxles kit (Tibus):
Firstly I would say it is very well made, I can't see that the exaxt stuff would be appreciably better, quality-wise. I understand they are splined in the factory which does the original Mog bits.
If your axles are staying under a Mog, I'd personally stay with something like this or the exaxt stuff to cope with the potential vehicle weight. Its really well made and the beefy brakes will be rated much higher than other options.
Here is some data on the other parts required to match the new hubs:
Caliper: Corvette from 69 - 82 front left Bendix nr.: R55329,
Raybestos nr. :RC8001, LCC Nr. : LS1001LF
right R55330
RC8002 LS 1001RF
Brake rotors Dodge W200 79-88 4500lb axle Raybestos nr. : Ray 7054,
Wagner nr. BD102137, ROT nr. ROT5350
Wheel studs: Chevrolet K20 4x4 front JD or JB7 brakes. Bendix nr.:
142138, Raybestos nr. RAY5012B, Dorman Nr. : DOR 610-180
Here are some pics of the fitment - there is a small amount of grinding to be done to the portal box:
Attached File  brake_mounting_003.1__Medium_.jpg   47.29KB   81 downloads
Attached File  brake_mounting_005.1__Medium_.jpg   49.9KB   69 downloads
Attached File  brake_mounting_008.1__Medium_.jpg   49.32KB   58 downloads
Attached File  brake_mounting_011.1__Medium_.jpg   38.48KB   62 downloads
Attached File  brake_mounting_014.1__Medium_.jpg   44KB   85 downloads
Attached File  brake_mounting_021.1__Medium_.jpg   53.14KB   67 downloads
Attached File  brake_mounting_028__Medium_.jpg   43.37KB   70 downloads
Attached File  brake_mounting_029.1__Medium_.jpg   47.93KB   71 downloads
Attached File  brake_mounting_038.1__Medium_.jpg   56.6KB   79 downloads
As a correction to Pugwash's comments - the Tibus/killeraxles kit also comes as an 8 lug conversion, not only with the original PCD.
If you are looking to pay - go killeraxles or exaxt, if you want to fab it all yourself, pirate 4x4 / weps is a great place to start.
In case you use the Tibus / killeraxles pinion conversions, here is the seal data:
Seal size for pinion conversion: 50,8 x 68,26 x 9,52mm
KingCJ - do you have a link to that supplier? I could use some bits!
Cheers, Al. :)
#6 king cj
king cj
    Member
  • Settled In
  • PipPip
  • 24 posts
Posted 20 June 2007 - 04:02 PM
www.usauto.co.uk
websites a bit carp but give them a ring they are friendly and helpfull
tel. 01234273155
#7 Astro_Al
Astro_Al
  • Settled In
  • PipPipPip
  • 2,133 posts
Posted 20 June 2007 - 04:08 PM
Cheers! Al :)
#8 mc4x4
mc4x4
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 20 June 2007 - 10:13 PM
Thanks guys for all the replys.
I spoke to tibus/killer axle yesterday and they are no longer doing disc brake kits.
I also spoke to exaxt and he was a nice bloke and is sending me a quot and an instruction kit.
I realy like Dirty diesels disc conversions I saw on his gwagen build up,does anyone have any more pics of this?
I would rely like to keep the stud pattern smaller, such as 5 on 5.5 so I might have to get my own hub made.
These axles were imported to Australia as a rebuilt item. They are going under my jeep Tj. We are looking at putting 9" centrs in them so we can get the ratio down.
Once agin thakyou for you replys, keep them coming
cheers mc
#9 pugwash
pugwash
  • Settled In
  • PipPipPip
  • 2,267 posts
Posted 21 June 2007 - 06:50 AM
did you speak to killeraxles in the US or germany? i spoke to Tibus last week and he was definitely doin brake kits still- it's all quite strange! The exaxt kit isn't going to be cheap but looks wel made- if you come across someone who has a kit then i wouldn't mind speaking to them!
Jim
#10 mc4x4
mc4x4
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 21 June 2007 - 10:09 PM
I spoke to the guy in the states from killer/tibus, which one did you speak to and did you get a name? I still have not heard back from exaxt yet. I spoke to a machine shop yersterday about getting some new hubs made and he doesnt think it would be a problem.
keep the repys comming
cheers mc
#11 pugwash
pugwash
  • Settled In
  • PipPipPip
  • 2,267 posts
Posted 22 June 2007 - 11:43 AM
we are in almost exactly the same place at the moment. Mac from Exaxt is a really easy guy to deal with, but can be difficult to get hold of!
I spoke to Germany, and i "think" it was woflgang who i spoke to- he was more than happy to send out a kit to me. I just wish i had written down the price he quoted! If Astro Al says that the tibus/killeraxle kit is good then that's enough of a recommendation for me!
I have also looked at getting new hubs machined up, and my local machine shop thought it wouldn't be too expensive or difficult even CNC'd from a solid block. BUT that still leaves the issues of finding rotors and calipers that work and spending ages getting the clearances right- whilst it's more than feasible to do it, for me i don't think the cost saving in money outweighs the extra time it would take me to do it! if you do go this route i would be very interested in hearing of any tips and kit that works for you.
Jim
#12 mc4x4
mc4x4
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 22 June 2007 - 11:06 PM
I am in the process fo going around some wreckers and getting some rotars and calipers of landcruisers patrols f100 and jeeps so we can find out differnet hat depths to work out which ones will work the best. I am thinking of using f100 rotar with landcruiser calipers because I am a jeep man and all my ther wheels are a jeep pattern.
We have two sets of mog axles so it makes it a bit easier, its always easier to get more things made.
cheers Mark
#13 bill van snorkle
bill van snorkle
    Old Hand
  • Settled In
  • PipPipPip
  • 2,717 posts
Posted 26 June 2007 - 11:23 PM
Anyone here know what type of material 404 hubs are made from and their weldability ? They appear to be SG/Nodular iron and I doubt that any engineer in Aus would sign off a disc conversion that involved welding wheel/rotor adaptors on to a cast hub, but I noticed while searching on pirate, that is one way some of the home brewed conversions are done.
Bill.
#14 dirtydiesel
dirtydiesel
    Old Hand
  • Moderators
  • 2,513 posts
Posted 26 June 2007 - 11:33 PM
Bill.
I'd say they're a conventional alloy steel, they certainly weld very well.
Dan.
Do. Or do not. There is no try.
#15 bill van snorkle
bill van snorkle
    Old Hand
  • Settled In
  • PipPipPip
  • 2,717 posts
Posted 27 June 2007 - 12:40 AM
Thanks Dan, If they are steel that would be excellant. We are presently having the axle pressed out of the hub so at this stage don't know if there is sufficient thickness of material in the top hat section of the Mog hub to permit drilling and direct fitting of Toyota wheel studs. If there is enough thickness then 60 series Toyota front discs and calipers appear to be good candidates for the conversion.
Bill.
