ibexman Posted October 21, 2005 Share Posted October 21, 2005 Anyone know where i can get hi lift jack mount that bolts to the spare wheel mount studs on a rear mounted spare wheel cheers chris Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 21, 2005 Share Posted October 21, 2005 I've never seen them in this country for sale except home made ones, do they look like this? that is a safari guard model, I dont even think Hi-lift do them! Enough strain on those back door hinges as it is!! Quote Link to comment Share on other sites More sharing options...
ibexman Posted October 21, 2005 Author Share Posted October 21, 2005 I've never seen them in this country for sale except home made ones, do they look like this? that is a safari guard model, I dont even think Hi-lift do them! Enough strain on those back door hinges as it is!! Thats what im after or something along those lines Quote Link to comment Share on other sites More sharing options...
Big Watty Posted October 21, 2005 Share Posted October 21, 2005 I think Mantec sell them - I have one if you want it but it's slightly bent where I caught the bottom of the Hi Lift on the ground! Oh and It's got alloy wheel nuts Quote Link to comment Share on other sites More sharing options...
Steve H Posted October 21, 2005 Share Posted October 21, 2005 Andy, Kaymar in Aus do them, someone in the UK probably carries their stuff , but with a couple of pics for inspiration, I don't think something like this would be too hard to cobble up, have a look on here. Kaymar Sorry for the choice of pic, first one I found Cheers, Steve. Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 21, 2005 Share Posted October 21, 2005 Have a look at: Wizard Have just looked on the website myself, and they are £35. I think that he sometimes puts stuff on here. I have nothing to do with this guy, apart from buying a ground anchor and ground anchor spade mounting kit from him. His quality seems absolutely excellent, and I have had no problems getting bits from him -I sent money, and he sent parts - just the way you want it. I saw his high lift jack mount when I went around to his house to pick up the ground anchor. I wouldn't want one, as I want my hi-lift inside the vehicle, but if I did want to mount it on the outside, I would definately buy his - it all seems very well thought out. As I say, I have no connection to this bloke, apart from being a satisfied customer (Cheque to the normal place, Mr. Wizard) Quote Link to comment Share on other sites More sharing options...
headhunter Posted October 21, 2005 Share Posted October 21, 2005 Have a look at the terrain master found at this url: http://www.4x4partsmaster.com/shop_det.asp..._id=&sec_id=245 John Quote Link to comment Share on other sites More sharing options...
Neil Marshall Posted October 21, 2005 Share Posted October 21, 2005 Have a look at these mounts below from the Australian company Kaymar. Popular over there. First is for universal placement: Next is for mounting on spare wheel carrier: Both look a simple DIY job to fabricate. Lower item is largely a short piece of box section with a backplate. Distributed in Europe by Outback Imports France - click here for email address. Neil Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 21, 2005 Share Posted October 21, 2005 sed to have one from terrain master. worked a treat, although: if you have a bearmach rear wheel carrier (don't know about other makes), the wheel is mounted "upside down" compared to the stock LR rear door mount... explenation: the LR door mount has the studs like this: o o o and the bearmach is: o o o as a result, the terrain master thingy is upside down. and a little "fettling" with Mr Angle grinder is called for. failing that, mine nver failed to impress, although i never quite felt happy about the wing-nuts holding it in place... i used to crank mine up with pliers each time, to be sure to be sure... Quote Link to comment Share on other sites More sharing options...
