Universal joints - propshaft
  • Please log in to reply
13 replies to this topic
#1 jwhitton
jwhitton
    Member
  • Settled In
  • PipPip
  • 73 posts
Posted 02 September 2007 - 09:34 AM
Just bought 2 x nice shiny GKN Universal Joints for my rear propshaft, notice they don't have grease nipples. Going to ring the supplier on Monday and check if this is correct!
All the ones on the usual online auction site has grease nipples where my current ones are on the prop, strange!
Guess they can't be sealed and I have been provided with the wrong UJ???
Help gratefully received.
Jon
#2 istruggle2gate11
istruggle2gate11
    The muppet formerly known as 898KOR
  • Settled In
  • PipPipPip
  • 1,164 posts
Posted 02 September 2007 - 09:50 AM
Jon, a big boy with big answers will be along shortly, but it used to be that Landie UJ's without grease nipples were for the joint between half shaft and stub axle on series 3 front axles. These didnt require greasing because the uj was bathed in oil. It used to be a common mistake to put greasable one in the axle and have fracture failure through the hole where the nipple should go.
Im not sure if later models came with sealed for life, but I cant think of any up to 1994. I would certainly replace them with greasable types.
Rog
The Ultimate Play Day - Kirton Off Road Centre
Neither of which had your world beating engine not to mention lockers, shafts, wheelbase and vast off-road driving experience
#3 Les Henson
Les Henson
    Still waiting to weld my new chassis :(
  • Supporters
  • 12,939 posts
Posted 02 September 2007 - 09:53 AM
I bought two U/J's for a 90 from Craddocks a few years ago. The box was almost identical to the Hardy Spicer ones, and that's what I thought I had bought. The U/J's had no grease nipples on them either, and it turned out they were chinese copies.
Les.
Keep this forum independent click here.
#4 jwhitton
jwhitton
    Member
  • Settled In
  • PipPip
  • 73 posts
Posted 02 September 2007 - 03:41 PM
Yes these are Hardy Spicer, said they were GKN since it says this on the back and couldnt remember what the brand name was.
These were from MM4x4 in Worcester, how did you tell they were copies?
Guess the correct ones should have grease nipples?
#5 western
western
    Recovery Man
  • Moderators
  • 31,232 posts
Posted 02 September 2007 - 03:55 PM
you'd be better off with the correct grease nipple fitted uj's, they non nipple uj's won't last long at all.
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#6 JimAttrill
JimAttrill
    So important that they banned 50 000 IP addresses to shut me up
  • Settled In
  • PipPipPip
  • 2,909 posts
  • Location:S 26°01.3' E027°58.5 1373m Johannesburg, South Africa
Posted 02 September 2007 - 04:01 PM
I suppose you could fit the 'sealed for life' ones, though I don't think the 'life' will be very long. I notice that some track rod ends come with grease nipples and some don't as well. We always try to fit the greasable ones. I reckon this is more important with UJ's ESPECIALLY the front one next to the transfer box because it gets the hardest life and fails the most often if not greased regularly.
Which reminds me to get out the grease gun... :rolleyes:
1996 Defender 300Tdi 110 csw
#7 jwhitton
jwhitton
    Member
  • Settled In
  • PipPip
  • 73 posts
Posted 02 September 2007 - 04:14 PM
Thanks for the help guys, think I will go back to basics...
For anyone with a EPC out there:
The LR part number on the Hardy Spicer box shows RTC3458G, is this correct for 1993 200TDi Defender 90 (JAxxx VIN number) for the rear prop?
Guess either way it looks like another trip to Worcester on Saturday.
Jon
#8 western
western
    Recovery Man
  • Moderators
  • 31,232 posts
Posted 02 September 2007 - 04:48 PM
Jon
Yes RTC3458 is correct :D for 90 rear prop both ends. :i-m_so_happy:
#9 Bull Bar Cowboy
Bull Bar Cowboy
    Happily Retired Old Hand
  • Settled In
  • PipPipPip
  • 2,089 posts
Posted 02 September 2007 - 05:47 PM
GKN’s definitely have grease nipples ………. I have two new GKN’s in boxes here. The correct place for the nip is to face inboard from the flange (ooooer….. I like that sentence :ph34r: )
Certainty for 90’s up to TD5 there were only two types ……. they are the same diameter but one is 7.62mm longer (in both directions) than the other. Rarely will you find them mixed on the same prop, but often the front can differ from the rear.
Ian
#10 Gromit
Gromit
    Old Hand
  • Settled In
  • PipPipPip
  • 1,616 posts
Posted 03 September 2007 - 02:28 PM
Jon
I've a hardy spicer sitting here for my 91 200tdi. No LR part number on it, but it has HS195 on the box.
Has nipples too :)
Gromit
A big white TD5 110.
Check out my video. There's a Land Rover in it!
#11 jwhitton
jwhitton
    Member
  • Settled In
  • PipPip
  • 73 posts
Posted 08 September 2007 - 09:04 AM
Just swapped them for Hardy Spicer Heavy Duty ones "coresponding to TUC100010" which now have grease nipples. Apparently the "normal" ones are now sealed and don't need greasing! Guess these are for propshafts that are used to go to the shop once per week and the hardest stress they face is a speed bump?
So if you want grease nipples and hence want to extend the life of the UJ you need to ask for the heavy duty ones.
Without being too cynical, has anyone used the "sealed for life no grease nipple required" ones?
#12 Gromit
Gromit
    Old Hand
  • Settled In
  • PipPipPip
  • 1,616 posts
Posted 08 September 2007 - 11:31 PM
Door stop?
Gromit
#13 Les Henson
Les Henson
  • Supporters
  • 12,939 posts
Posted 09 September 2007 - 09:21 AM
Butch gear knob? :unsure:
Les.
#14 jwhitton
jwhitton
    Member
  • Settled In
  • PipPip
  • 73 posts
Posted 09 September 2007 - 03:18 PM
Sharking fishing line weight?
