Oil sump sealing...
  • Please log in to reply
13 replies to this topic
#1 Michele
Michele
    Cube driver & LR cartoonist
  • Settled In
  • PipPipPip
  • 1,457 posts
  • Location:A small mountain village in the Northern Apennines,surrounded by rocks and forests...
Posted 28 October 2005 - 08:08 AM
Right,
it's about time for my Cube to receive the 90'000 Km. service.
This time,for no particular reason (other than the nice weather)
I'm planning to pull the oil sump down while changing the oil,
give it a good cleaning,and replace the sealing.
The guy at the garage suggested to use the black paste (sealer?)
instead of the paper gasket.
Any particular care has to be taken when applying the paste?
I noticed some draw a "zig-zag" path.
Any advice?
TIA!
D90 VNTdi The Cube II ©  1965ish ex-mil 109" IIA Rollergirl
whitedogrover.com
http://whitedogcomics.blogspot.it/
Land Rover Cartoons & More!
#2 white90
white90
  • Settled In
  • PipPipPipPip
  • 9,649 posts
Posted 28 October 2005 - 09:32 AM
make sure everything is as clean as possible and the weather not to cold.
use RTV silicon not too much of it either, allow to dry before re filling it with oil.
Tony
Keep this forum independent click HERE.
#3 Michele
Michele
  • Settled In
  • PipPipPip
  • 1,457 posts
Posted 28 October 2005 - 10:03 AM
Hello Tony.
OK,I have a nice plastic scraper
:D
Do I have to squirt the black paste in alternate way or just straight along the edge?
Does it matter?
whitedogrover.com
#4 FridgeFreezer
FridgeFreezer
    Director of authenticity
  • Supporters
  • 18,204 posts
Posted 28 October 2005 - 10:25 AM
Nige B swears by the official Land Rover black goop - I think you can buy it from the motor factors for similar money but in a normal (EG bigger) sized mastic gun cartridge. Very handy stuff it is too!
Not built my engine yet so couldn't say how well it works on the sump :unsure:
Yes*
*No
#5 Diff
Diff
    Likes a Limited Slip!
  • Settled In
  • PipPipPip
  • 861 posts
Posted 28 October 2005 - 10:48 AM
Hi Michele,
Make sure you degrease all surfaces really well with a proper degreaser, cellulose thinners or anything else that doesn't leave a residue. A single straight line in the middle is sufficient, with a small circle around each bolt hole too. As Tony said, you need to let it dry properly after bolting the sump back on for best results. I suggest a minimum of overnight before refilling with oil and starting the engine.
Regards, Diff
#6 Michele
Michele
  • Settled In
  • PipPipPip
  • 1,457 posts
Posted 28 October 2005 - 10:50 AM
I got the ubiquitous Arexons,it should work.
If it'll leak,well I'll do the job again.
:P
whitedogrover.com
#7 NegevLandRover
NegevLandRover
    Go Directly to Jail
  • Supporters
  • 223 posts
Posted 28 October 2005 - 05:17 PM
Just done mine on the new engine, along with my trusty garage owner who lets me work with him - I do not have the facilities time or know how to do it all alone.
The main thing was getting the two surfaces clean, de-greased and dry before starting with the new sealer. We did a simple one line with a circle around each hole. The trick is getting it on in one clean sweep so as not to smudge the bead. We did it with two people - while I held the pan about 5 mm below the engine my M8 put in 4 bolts one at each corner and the we left the sump hanging on those and placed all the other bolts and then did up the opposite ones leaving the final tightening till last and then doing that bit by bit so as to get a nice even seal.
Name of the game is patience patience.
Mine, 2K later is nice and dry !!! :D :D
Adam
LRs don't leak - they sweat, and if it ain't sweating then it must be empty !!
1994 Defender 110 (ex-200tdi) now running 300tdi and R380 gearbox.
1997 Defender 110 300tdi - rebuilt from scratch. 1998 Disco 300 TDI EDC
<span style='font-size:14pt;line-height:100%'>My Web Site</span>
#8 Ben Reedy
Ben Reedy
    No-one is as smug as me
  • Settled In
  • PipPip
  • 60 posts
Posted 29 October 2005 - 06:36 AM
Why?
I took mine off to fix the leaks and found that despite being carefully applied as described above, it was still uneven and leaking in places.
Put a paper gasket on and for 5 years it's been so dry that the bolts are even rusting.
#9 Les Henson
Les Henson
    Still waiting to weld my new chassis :(
  • Supporters
  • 12,934 posts
Posted 07 November 2005 - 11:24 PM
I had a heck of a job removing the sump pan on catflap because it's glued on by RTV sealant. I cleaned it all off and used a series paper gasket too. The better quality ones are quite thick.
Don't know about leaks yet as I haven't got round to starting the engine yet!
Les. :)
Keep this forum independent click here.
#10 Michele
Michele
  • Settled In
  • PipPipPip
  • 1,457 posts
Posted 08 November 2005 - 02:33 PM
Job done!
2 times...
(DOH!)
:rolleyes:
Sump off,lot of thinner,went almost as new.
Sealer out,but-guess what?-more than a half had dried out.
I tried to apply it as best as I could,then re-fitted the sump.
Fresh oil in.
New filter.
Off for the weekend,checked the pan out the day before and it leaked (damn).
Oil out again,sump down,brand new paste and here we go again.
Now perfect,everything is clean and dry.
B)
whitedogrover.com
#11 LR90
LR90
    Cave arbores!
  • Admin
  • 4,467 posts
Posted 08 November 2005 - 03:31 PM
Is a paper gasket available fo rthe TDi?
Trev
LR90.com 109 2A, 110, 90 & Disco Cave arbores!
#12 landi41
landi41
    Just an ordinary Joe
  • Settled In
  • PipPipPip
  • 428 posts
Posted 13 November 2005 - 05:16 AM
Not sure about the TDi but my money is on the paper gasket...we smeer them with something called
Permatex II, black and sticky but sets up rubbery............. can you Lads get it over there....?
"One Life Live It" (till the gas runs out) Dave from... Posted Image
#13 western
western
    Recovery Man
  • Moderators
  • 31,227 posts
Posted 13 November 2005 - 09:13 AM
There's no paper/card type sump gasket for 200/300Tdi engines, LR built them fitted with rtv sealant - STC611, a 2.5 n\a or TD sump gasket might fit, but I reckon the bolt holes will be in the wrong place.
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#14 Les Henson
Les Henson
  • Supporters
  • 12,934 posts
Posted 13 November 2005 - 10:33 PM
Sounds the same as RTV sealant to me. Very similar to silicone, but it seems to me to be more runny and sets quicker too. If I'm fitting a new gasket to a pitted surface I put an additional thin layer of RTV sealant on it as well, just to be sure.
Les. :)
