300 tdi Viscous fan removal
  • Please log in to reply
9 replies to this topic
#1 Ryan
Ryan
    I know where you are...
  • Long Term Supporters
  • 1,124 posts
Posted 03 October 2007 - 08:44 PM
Very shortly, I will be replacing the radiator on my 1994 300tdi Discovery. I'm sure I've seen somewhere that the viscous fan nut comes in two flavours. Any idea which one I need? Or will it be a matter of buy both and take back the one that doesn't fit?
2001 Land Rover Freelander TD4
SLRC Facebook Page
@shirelrc on Twitter
#2 Corrode Finger
Corrode Finger
    Resisting the return to LR's!!
  • Settled In
  • PipPipPip
  • 722 posts
Posted 03 October 2007 - 08:48 PM
Might be wrong, sure someone will say, but i think its a 32 flavour, if it is, i think i have one that you could borrow, if that helps, save buying one?
Welcome to the fold Brother Corrode
#3 Ryan
Ryan
  • 1,124 posts
Posted 03 October 2007 - 08:59 PM
Cheers, can you bring it along on Thursday and I can see if it will fit?
SLRC Facebook Page
#4 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,153 posts
  • Location:Third rock from the Antarctic - 5141.8'S 5750.5'W
Posted 04 October 2007 - 10:19 AM
32mm spanner size nut on a 300Tdi, and 36mm on a 3.9 V8. Not sure what the thread measurement is. There is only one part number that I am aware of for a 300Tdi viscous, which is ERR2266.
HTH :)
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#5 Ryan
Ryan
  • 1,124 posts
Posted 04 October 2007 - 01:39 PM
Sorry, it would have helped if I'd worded my query correctly in the first place - I was just after the spanner size. Thanks for the replies, hopefull Mr Finger will be the supply of said item tonight.
SLRC Facebook Page
#6 Corrode Finger
Corrode Finger
  • Settled In
  • PipPipPip
  • 722 posts
Posted 04 October 2007 - 10:20 PM
Had the spanner, but it did not fit due to the restricted space, so Ryan is still in need of the correct one to remove the viscous fan, so if anyone else can help?
#7 Ryan
Ryan
  • 1,124 posts
Posted 04 October 2007 - 11:13 PM
I think I may be ok. I've had some "advice" which says I can change the rad without removing the fan. If necessary, Mr Popay says he has a spanner if needed.
SLRC Facebook Page
#8 JimAttrill
JimAttrill
    So important that they banned 50 000 IP addresses to shut me up
  • Settled In
  • PipPipPip
  • 2,909 posts
  • Location:S 2601.3' E02758.5 1373m Johannesburg, South Africa
Posted 05 October 2007 - 10:07 AM
A 'normal' 32mm spanner will not fit unless you grind it to make it thinner. I thought this was a bit of a waste of a good spanner so used a bit of old leaf spring - a couple of cuts with an angle grinder and I have a perfect 'special tool'.
1996 Defender 300Tdi 110 csw
#9 Ryan
Ryan
  • 1,124 posts
Posted 05 October 2007 - 10:40 AM
Not many leaf springs on a Discovery though.... :P
SLRC Facebook Page
#10 JimAttrill
JimAttrill
  • Settled In
  • PipPipPip
  • 2,909 posts
Posted 08 October 2007 - 12:22 PM
Well, the leaf spring I used was off a Ford....
