LDRover Posted December 2, 2007 Share Posted December 2, 2007 Can anyone tell where the Heater Blower Relay is mounted on a Discovery S1 1993 model. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
LDRover Posted December 5, 2007 Author Share Posted December 5, 2007 Plaese help cannot see in a moring through the damp screen. Can I bypass the relay and take power to the fan speed switch. Thanks. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 5, 2007 Share Posted December 5, 2007 Sorry the tech info I have only starts with the 300Tdi 1995 onwards - hopefully somebody out there has a copy of the older workshop manual... Quote Link to comment Share on other sites More sharing options...
lynall Posted December 6, 2007 Share Posted December 6, 2007 Not sure on 200 but 300 is behind the panel to the right of the throttle pedal, so maybe worth a look. I should know as i had a eberspacher heater on my last 200 but as i am getting old and senile maybe its not! Lynall Quote Link to comment Share on other sites More sharing options...
pinkbeef Posted December 31, 2007 Share Posted December 31, 2007 The Relay is behiend a small panel by the throttle pedel as Lynall has said, and the relay is the first from the door with two thick white/green stripe wires and thin black and thin green wire going into it. when you turn the ING on you should feel a click. white/green wires ING on + 12 volts black wire eirth green ing on + 12 volts if thats OK it works and the fault is elsewhere. Quote Link to comment Share on other sites More sharing options...
michael100 Posted January 1, 2008 Share Posted January 1, 2008 Hi There, Above answers are correct the blower motor relay is behind drivers footwell side panel, below the main relay bank. The wire on your heater switch that is the direct feed from the battery to the heater blower is the white/light green. if this still doesnt work then connect a live straight to the blower itself. the colour of wire @ the blower is white/ grey. Regards Quote Link to comment Share on other sites More sharing options...
LDRover Posted January 6, 2008 Author Share Posted January 6, 2008 Thanks, Replaced the relay and I now have heat again. Quote Link to comment Share on other sites More sharing options...
tedmason Posted October 26, 2008 Share Posted October 26, 2008 Hi everyone, i've just joined after doing a google search for my problem and it led me here. The 'official' LR site isn't interested unless you have a week old disco! I have the same problem, '93 TDI with no heater blower. There is no apparent panel to remove in the footwell to the right of the throttle, just the whole trim panel, do I have to remove the whole thing? It just seems to be a silly thing to do! but then, so is having to remove the rear seat to change a bulb!.........lol Many thanks. Quote Link to comment Share on other sites More sharing options...
tedmason Posted October 26, 2008 Share Posted October 26, 2008 Thanks,Replaced the relay and I now have heat again. Hi everyone, i've just joined after doing a google search for my problem and it led me here. The 'official' LR site isn't interested unless you have a week old disco! I have the same problem, '93 TDI with no heater blower. There is no apparent panel to remove in the footwell to the right of the throttle, just the whole trim panel, do I have to remove the whole thing? It just seems to be a silly thing to do! but then, so is having to remove the rear seat to change a bulb!.........lol Many thanks. Quote Link to comment Share on other sites More sharing options...
kelvin1950 Posted October 23, 2009 Share Posted October 23, 2009 Thanks guys, this helped me a lot. Quote Link to comment Share on other sites More sharing options...
marty1a Posted October 24, 2009 Share Posted October 24, 2009 Have the same problem in a 1991 disco v8i. Blower motor won't work and the relay is clicking when ign is turned on. How hard is it to replace the blower motor??? Regards Marty Quote Link to comment Share on other sites More sharing options...
kelvin1950 Posted October 25, 2009 Share Posted October 25, 2009 Have the same problem in a 1991 disco v8i. Blower motor won't work and the relay is clicking when ign is turned on. How hard is it to replace the blower motor??? Regards Marty From what I can see, it's a right pain. Centre console out and radio console out. The CC looks as if it will be fun to remove. Hoping that my relay replacement will fix it, I'll know on Wednesday. Quote Link to comment Share on other sites More sharing options...
