Heated rear window failure
  • Please log in to reply
2 replies to this topic
#1 Dorsetfreelander
Dorsetfreelander
    Old Hand
  • Settled In
  • PipPipPip
  • 215 posts
Posted 18 December 2007 - 08:07 PM
I have an 04 reg TD4 auto SE spec freelander. I have discovered that the heated rear window doesn't seem to warm up. The front screen heater works fine. I have checked the fuse and the relay which controls the rear window heater and no problem there (ie the relay clicks in and out OK and I have even taken it out to check that the relay is functioning properly). The next step is to take the back door inside cover off or does someone have any suggestions for other points of failure before I start on that?
Cheers Dennis
#2 andyb
andyb
    All Round Action Man
  • Settled In
  • PipPipPip
  • 721 posts
Posted 18 December 2007 - 08:24 PM
I reckon my first port of call inside the door would be the supply wires to the heating element. Use a volt meter to chcek that you actually have power to the heating element when it's switched on.....will at least rule out a break in the element in the windows itself.
HTH
Andy
Try SCOR for the best trials and comp safari in the south of England
#3 jules
jules
    Old Hand
  • Settled In
  • PipPipPip
  • 3,976 posts
Posted 19 December 2007 - 11:52 AM
Cheers Dennis
I take it the guarantee has now run out.
You right the cover off is you best bet give all the cables a good grease up while you in there it will save you a fortune in years to come.
Probably something stupid like the pug has fallen off inside the door
Stunning in boscombe fixed my back door last time if broke.
Jules
Dents are like scratches with a better story
