LR4x4 - The Land Rover Forum: Rear floor & body cross-member replacement - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Rear floor & body cross-member replacement on a 92 RRC - lots of pics
#1 User is offline   Orange
  • Old Hand
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 01 February 2008 - 10:51 PM
On a sunny day in the summer of 2007, I enlisted the help of Mark to replace the floor and rear body cross-member in my 92 Range Rover Classic. The full size pictures are in one of my LR4x4 albums if you want to view full size ones!!
We started with this:
Posted Image
Went through this:
Posted Image
And approximately 2 weeks later (4 solid days and a load of tarting up) ended up with this:
Posted Image
There’s more to it than that though!!!!! I’ve got a load of pictures of the whole process (pm me if you want anything specific) but I thought a brief description of the work was best, so here goes…
Firstly, the rear of the car was stripped of it’s carpets, lights, seats, tailgates and sundries (anything flammable, basically!!) so we started with room to move and room to investigate.
Posted Image
Then the fun really starts… Let’s see how far the rust actually goes:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
You get the idea!!!
First thing to do is the remove the rear crossmember. There are loads of spotwelds to drill out, so best to get at least one spotweld drill bit.
Posted Image
There are some that are hidden and will involve bending various bits of metal to get a cold chisel to!!
When you get close to the point of complete detachment, best to prop the sides up with something adjustable. This will make it easier to wiggle the replacement one in! It will be easier if you are just using box section and fabricating body mounts, but an original one piece crossmember requires quite a bit of jiggling!
Old one out:
Posted Image
The replacement crossmember from (I think) an ’83 model given a good wire brush and a coat of weldable primer:
Posted Image
Then cut the rest of the floor out:
Posted Image
And wiggle the replacement crossmember in and clamp it in place:
Posted Image
Then do up the new body mounts (tight, but not silly tight) and tack it in place. After it’s all lined up, it’s time to get the Welding Bitch to do his thing… Including re-fitting the rubber seal mounting flange:
Posted Image
You can probably see from the last picture that there was nothing left or the floor supports at each side. Now is the time to enlist the help of your favourite local blacksmiths to get them to fold some flat sheet steel to create a new lip (cheers Messers RogueVogue and Wightman) using their uber-good press and gilloutine equipment. We could only manage to fold one section, when we actually needed a double fold to create the new step and overlap the existing metal. This meant welding a flat strip of steel to the folded section. I haven’t explained it very well, but this next picture gives you the general idea of what was needed/achieved:
Posted Image
Add in the new floor supports (same as Disco 1 ones) and you end up with what Land Rover intended to hold the floor up.
During the process of attaching the new floor support sections, we blew several holes in the wheelarch, so ended up making running repairs:
Posted Image
Posted Image
Once that was all done, it was time to turn attentions to repairing the offside wheelarch and door pillar. After a good grind and wire brush the looked like this:
Posted Image
Posted Image
Bear in mind you can see the floor through the wheelarch!!
Posted Image
After several plates were cut and shaped, we ended up with repair that looked like this:
Posted Image
Posted Image
Posted Image
The extent of the primer gives away how much was repaired!!! The primer has been applied after a good layer of seam sealer was worked into all of the welds/overlaps.
Posted Image
Posted Image
Posted Image
A quick slap of silver paint:
Posted Image
Then we come to putting the new floor in. This was recovered, along with unperished rubber sealing strips, from a pre 1986 model in a scrapyard. I think it cost £20 in total – Mark will correct me if I am wrong!! (As usual!!)
Posted Image
Tell you what – if you are doing this and don’t have an air rivet gun, go out and buy one!!!!!!!!!!
The floor was put in with a liberal application of sealant to all joins, even along the rubber strips.
With all that done it was a case of rebuilding the rear end with it’s wings, tailgates and lights and away we go!!
All in, the cutting, fabbing and welding took about 4 days. The strip down and prep/painting and rebuild after took a further week of evenings. A bit long winded, but it’s now more solid that it was when it left the factory!!!
As I said above, there’s loads of piccies if you want any specific areas in detail!!
I'm sure Mark will be along in a little while to explain more of the tech side of things. AFAIK his welder is a Butters MIG 175, but that's about it...
Yes I was discriminated against through my early years!!
1995 300 TDi 90 with a few toys
2002 TD5 Discovery 2..........now IRB'd and re-clutched!!
1992 RRC 3.9 Auto + ongoing mods - A little write-up
#2 User is offline   Bowie69
  • Permanently befuddled....
  • PipPipPip
  • View blog
  • Group: Settled In
Posted 02 February 2008 - 12:00 AM
Some really nice work there! And many thanks for the great write up =)
I guess being pre-1986, you mean the floor is Ali?
I am thinking this may need doing to mine sometime soon...........
 1980 2.25 FFR Lightweight
1991 (late) 4.0 V8 Range Rover Classic Vogue SE -now on MegaSquirt! (undergoing modifications....)
#3 User is offline   Mark
  • Diesel Head
  • PipPipPip
  • View gallery
  • Group: Admin
Posted 02 February 2008 - 12:13 AM
The floor we replaced was in a 92 but I think the ally floor came out of an '84 car (it was on an A plate)...
The ally floor seemed like a much better idea than our original plan of cutting and shutting a discovery floor to fit. The ally floor also does not have 2 of the supports that the steel floor has, so we didn't replace them. I wish I had done it this way on my disco to be fair!
The main bits that took the time were the fiddly bits like the bottom of the C-pillar. The wheel arch was fun, and involved riveting the new metal in place to hold it while I welded it in properly.
The repair pieces along the edge of the floor, to create the recess for it to sit in, were something like 40mm x 15mm x 25mm. 40 mm sits flush against the side of the wheel arch and puts the 15mm step in the right place. As has been said, the brake press didn't have the tooling to do such a shallow step, so they were made as 2 pieces welded together to form the section.
There isn't much technical stuff to get into here. It's not a fun job to be honest, but replacing the cross member is whole lot easier with no floor in place.
The rust doesn't look too bad in some of the pictures, but I only planned to do this once, so it all got done together!
As Adrian has failed to mention, The truck is up for sale now, so if anyone wants a rangie with a very solid rear end, this is it!
Cheers
Mark
[O]====[O] '91 200 Tdi Disco (RIP) & '96 300 Tdi Disco
[" ]O#O[ "]
'68 SIIa LWB Diesel - Restored and now For Sale!
Help keep this forum independent - click here.
#4 User is offline   Bowie69
  • PipPipPip
  • View blog
  • Group: Settled In
Posted 02 February 2008 - 01:07 AM
ARGH... don't tempt me with it again! :(
#5 User is offline   steve_d
  • Old Hand
  • PipPipPip
  • View gallery
  • Group: SVA Gurus
Posted 02 February 2008 - 07:45 AM
Nice job.
I have an ali floor going begging if anyone wants it.
Steve
Steve. M3BBH RAYNET
Built a Dakar from my faithful but rusted out Classic.
#6 User is offline   Orange
  • Old Hand
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 02 February 2008 - 07:48 AM
Quote
[Mrs Doyle voice on]
Ah - go on, go on, go on!!!
[Mrs Doyle voice off]
#7 User is offline   Rustyrangie
  • Member
  • PipPip
  • View gallery
  • Group: Settled In
Posted 09 February 2008 - 04:54 PM
Nice job, Orange
I did the same to my '90 Vogue
Having stacks of time and little money (early retired and a cheapskate!) I made up all the floor support panels from 20 gauge sheet with a clark bender.
The floor is a Disco one which is about 4 inches too short. I fitted an extra floor support bar above the fuel tank and used 20 gauge sheet to fill the gap to the rear crossmember.
The disco floor has all the holes (Seat belts & fuel pump access) in the right place if you do it this way.
Bob
#8 User is offline   Shackleton
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 29 February 2008 - 11:42 PM
Nice! Didn't realise thats what the rear cross member looked like
Question though - see the way you can look down your chassis rails once the rear bumper is off, as in inside the rails...
Is that normal cause if so mine have been capped front and rear, or maybe were the early cars capped and not the later ones?
PS - is that a big green classic bus your RR sleeps with?
#9 User is offline   Orange
  • Old Hand
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 02 March 2008 - 07:04 PM
The chassis is blanked off about 3" from the rear crossmember... Don't know if Land Rover made any alterations to this set-up. My previous 1987 Vogue is exactly the same...
As for the classic bus - yes and no. Yes, It's a GreenLine RF. It's my dad's hobby!!! And No, it doesn't sleep with it. I can only blag workshop space for a few days at a time as where the RR is parked, another bus normally lives!!! Bl##dy parents - how dare they fill their own workshop up with their own stuff!!!
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
