LR4x4 - The Land Rover Forum: Hazard Switch & Indicators - fault diagnosis - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Hazard Switch & Indicators - fault diagnosis tech article
#1 User is offline   LandyManLuke
  • Old Hand
  • PipPipPip
  • View gallery
  • Group: Moderators
Posted 12 April 2008 - 09:53 PM
I wrote this for another forum, I thought it might be useful here too.
The hazard switch and indicators often cause problems in defenders, most commonly the indicators stop working, but the fault is actually with the hazard light switch.
This post aims to explain how the hazard switch works, why it's malfunction stops the indicators working, and how to test for and diagnose the fault.
To get to the back of the hazard switch, remove the two screws and pull the switch panel out. you'll then see this.
Posted Image
The multi plug has 7 wires going into it, there's also the Black (red trace) and Black wires, which are connected directly to the switch body. these are for the indicator in the switch itself.
Black(red) - indicator supply
Black - earth
Remove the multiplug, you will then see the two sets of pins, x3 and x4, top and bottom (as viewed in the photo, not as mounted in the dash).
The top set are concerned with powering the flasher unit, the bottom set dictate what the flasher unit actually lights.
Posted Image
This picture shows the 4 wires that connect to the bottom set of pins
Posted Image
And this picture shows the 3 wires that connect to the top
Posted Image
To make things easier to see, here is a schematic of the switch.
Posted Image
With the Hazard switch in the 'off' position
'Suppy to flasher' is connected to 'Light switch supply' - which comes on with the second click of the ignition switch
With the Hazard switch in the 'on' position
'Suppy to flasher' is connected to 'Permanent Supply' - 12vDC
*Flash* is connected to 'Left Indicators', 'Right Indicators', and the 'Switch tell-tale'
What this means is, if the switch is faulty, the flasher unit doesn't get a power supply, so it can't flash the indicators via the indicator switch on the column.
You can test the switch using a multimeter (continuity or resistance), or test lamp. You can also test the vehicle wiring as follows.
You will need a fused piece of wire (or test lamp), you don't want to risk a dead short if you get it wrong.
This is what i made to test the wiring, the lowest value fuse i had was 5A.
Posted Image
If you link 'permanent supply' (purple) to 'Left indicators' or 'Right indicators' the indicators on that side should light, constantly though, not flashing. this proves the bulb wiring is ok and you have supply to the loom plug.
If you link 'permanent supply' (purple) to 'supply to flasher' (light geen), the indicator stalk switch should work the indicators as normal (flashing). The indicator switch is connecting *flash* to 'Left Indicator' or 'Right Indicator' - the wiring is duplicated at the stalk switch. If you want to make a seperate link wire you can replicate the stalk switch action at the loom plug as well.
You can repeat the two tests above, using 'Light switch supply' instead of 'permanent supply', the ignition switch will need to be on the second click.
'Switch tell-tale' is the live supply to the bulb in the switch housing, it is grounded by the seperate black wire connected to the switch body.
Keep this forum independent, click here
#2 User is offline   western
  • Recovery Man
  • PipPipPipPip
  • View gallery
  • Group: Moderators
Posted 12 April 2008 - 09:56 PM
Another Great effort Luke :D
I'll have a link put in the Tech Archive.
Ralph,M3WRM,MSA Recovery Operator -- Western Recovery [Motorsport]
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#3 User is offline   neill.bird
  • Newbie
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 20 January 2010 - 04:05 PM
thanks a mil this helped me no end today. In the end it was the fuse for the hazzards that made them not work. But i learnt how they work in the process.
THANKS.
M reg 1994 110 300Tdi CSW (MA9xxxxx)
#4 User is offline   Mo Murphy
  • Broad Minded
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 21 January 2010 - 12:16 AM
Good write up Luke, nice and clear.
Mo
The Land Rover 90: Many are called, few are chosen ...
#5 User is offline   Tree Surgeon 130
  • Newbie
  • Pip
  • Group: New Faces
Posted 28 February 2010 - 06:57 PM
For info, the wire shown as dark green here is white with a green trace in the TD5 defenders. Make sure this is not confused with the green with white trace wire.
Kev
#6 User is offline   Maverik
  • Newbie
  • PipPipPip
  • Group: Settled In
Posted 08 July 2010 - 11:58 AM
Kev
Also for info, for a TD5 HZ switch, to get the little light in the button to illuminate you join the black/red wire with the orange/red wire.
My 86reg 90 with original loom, the dark green wire had a small white rubber band marker on, this attaches to the White with green trace wire as Kev says.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
