oil filter wrench?
  • Please log in to reply
24 replies to this topic
#1 renault4
renault4
    Member
  • Settled In
  • PipPip
  • 137 posts
Posted 02 May 2008 - 07:18 PM
can anyone recomend an oil filter wrench/spanner /socket for a defender 90?
I have one that is like a piece of chain with a socket on the end which works fine on other cars where
access is not such a problem, but on a defender?.
#2 Scotian
Scotian
    0 Horse Power
  • Settled In
  • PipPipPip
  • 563 posts
  • Location:Craiova (Romania), Bedroom, on the edge of the bed :-)
Posted 02 May 2008 - 07:29 PM
I've got a very cheap bike chain thingy with a pressed steel handle. I had no problem getting my filter off. Also use it to hold the shocks tight while undoing and doing up the nuts :)
1985 Landrover 90 200TDi Disco engine, Disco rear axle, 2 inch lift and BLACK
Check out my last weekend Here :) This will explain my Avitar name :-S www.youtube.com/xpowerracer
Why was there a dead dog under my landrover in the morning????
#3 ChrisV8
ChrisV8
    Old Hand
  • Settled In
  • PipPipPip
  • 225 posts
Posted 02 May 2008 - 07:37 PM
I have one of these works really well
http://www.screwfix....n...mp;x=10&y=2
you can get a very similar one from Machine mart as well
1982 Range Rover 200tdi inside
1993 90 200 tdi Project
2008 JEEP Patriot and 5000.00 change and 45 mpg compared with a Freelander 2 !
#4 LR90
LR90
    Cave arbores!
  • Admin
  • 4,467 posts
Posted 02 May 2008 - 07:58 PM
^^^ yep, that's what I use as a last resort and not failed me yet, excellent piece of kit. IIRC mine came from halfords.
Trev
LR90.com 109 2A, 110, 90 & Disco Cave arbores!
#5 Les Henson
Les Henson
    Still waiting to weld my new chassis :(
  • Supporters
  • 12,931 posts
Posted 02 May 2008 - 08:01 PM
I have the chain type and have used it for years - even on defenders. The TD5 would be better off with the strap type though as the filter is very rogue trooper tight :P
Les :)
Keep this forum independent click here.
#6 Night Train
Night Train
    Old Hand
  • Settled In
  • PipPipPip
  • 1,154 posts
Posted 02 May 2008 - 09:22 PM
I've often wondered if they worked.
I have the old chain on a lever thing that generally tears the filter can apart before it loosens it. It was as useful as stabbing the can with a screwdiver and then levering it off.
#7 mmgemini
mmgemini
    Old Hand
  • Settled In
  • PipPipPip
  • 4,407 posts
Posted 02 May 2008 - 09:35 PM
Vehicle Wiring Products do those as well
mike
mike
Quis custodiet ipsos custodes?
I can cause trouble in an empty house !
#8 western
western
    Recovery Man
  • Moderators
  • 31,137 posts
Posted 02 May 2008 - 10:04 PM
I don't use one, I just grab it tightly & unscrew the filter by hand.
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#9 freeagent
freeagent
    Old Hand
  • Settled In
  • PipPipPip
  • 1,790 posts
Posted 02 May 2008 - 10:43 PM
i've got one like the screwfix one... works brilliantly, the more force you put on it, the tighter it gets.... it'll crush the can rather than slip...
currently without a 4x4 as life is getting in the way!
#10 Eightpot
Eightpot
    Old Hand
  • Settled In
  • PipPipPip
  • 1,186 posts
Posted 02 May 2008 - 11:05 PM
girls.
real men use a screwdriver hammered through the filter.
#11 Guest_noggy_*
Guest_noggy_*
  • Guests
Posted 03 May 2008 - 07:22 AM
i found that the strap type with the lever didnt work so well in some tight applications, so i bought one of these.
you use it with a normal ratchet so its easy to use in tight spaces.
http://www.diytools......00mm-cap).asp
Posted Image
#12 tuko
tuko
    Good old Boy
  • Settled In
  • PipPipPip
  • 1,432 posts
Posted 03 May 2008 - 08:39 AM
Ralph,
were you a professional wrestler by the name Killer Karl Krup who's finishing move was "The Claw"
He had the claw of death!
LOL :lol: :lol: :lol: :lol:
Seriously,
I use the same tool as ChrisV8, works perfectly gripping firmly releasing the seal directly.
Cheers,
Todd.
This is a technical forum, NOT a social networking site
My 300Tdi Series Hybrid
Småland Traxx
#13 Bigwood
Bigwood
    Member
  • Settled In
  • PipPip
  • 148 posts
Posted 03 May 2008 - 06:43 PM
Ralph,
Seriously,
Cheers,
Todd.
We use the strap type wrench on the buses we service. I have a Sykes Pickavant now, the second wrench I have had since the seventys. A filter on a new cumins engine broke my first one two years ago, that was strap wrench grunt bar and a peice of tube on the handle. We fitted a filter head comple asuming the Yanks had thread locked the old one on. :angry:
#14 western
western
    Recovery Man
  • Moderators
  • 31,137 posts
Posted 03 May 2008 - 07:43 PM
Ralph,
Seriously,
Cheers,
Todd.
I've a fairly good grip & when fitting the oil filter I just smear the seal with a film of engine oil & tighten the filter by hand.
#15 istruggle2gate11
istruggle2gate11
    The muppet formerly known as 898KOR
  • Settled In
  • PipPipPip
  • 1,164 posts
Posted 03 May 2008 - 07:54 PM
Tried all the above^^^^^
Now I just use a set of plier type grips from Halfords 10 IIRC cant be faulted.
Rog
The Ultimate Play Day - Kirton Off Road Centre
Neither of which had your world beating engine not to mention lockers, shafts, wheelbase and vast off-road driving experience
#16 Tris Cocks
Tris Cocks
    Old Hand
  • Settled In
  • PipPipPip
  • 272 posts
Posted 03 May 2008 - 09:10 PM
another way of removing the filter that i have used is by wrapping a long length of rope around the filter so that when i pull on it, the rope tightens and unscrews the filter. if you have the first few layers of the rope overlapping it makes sure that it doesnt slip.
HTH
Tris
1998 Defender 90 CSW
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
#17 mickeyw
mickeyw
    Petrol Head
  • Long Term Supporters
  • 2,931 posts
Posted 03 May 2008 - 09:57 PM
I have used chain wrenches and strap wrenches in the past and binned them all. The first LR I worked on with a spin on canister was a 2.5 TD. There is so little room to move a wrench, the strap stretched too much and I ran out of space, the chain wrench just chewed the filter up - big mess. My favoured tool became a Sykes Pickavant tool bought in Halfords, it's similar to the Screwfix item mentioned above and has never failed to move a filter, without wrecking it in the process.
Having said this I have never need a wrench for a V8 filter due to it being so easily accesible to both hands.
Michael
Michael
1986 Ninety 3.9 EFI Auto LPG 'Jolted' | 1990 Range Rover Vogue SE Auto LPG | 1986 One-Ten CSW 3.9 EFI LPG Jolted
#18 dantd5
dantd5
    Old Hand
  • Supporters
  • 1,047 posts
Posted 03 May 2008 - 09:58 PM
:blink: I am with Western on that. I do use the "Grab-and-hold-your-breath-while-wrenching-til-it-gives-up" method and it works well with me.. ( Haven't been a wrestler nor a strangler :huh: )
Real men do the wrenching method aintdatright? ;)
Electrickery. PRoblem was deep horn trafikator switch. I changed it and vips all was working again!!
...Defender 110 Td5 99 Model
#19 sheltie50
sheltie50
    Old Hand
  • Settled In
  • PipPipPip
  • 289 posts
Posted 04 May 2008 - 12:40 AM
It's only fitted "hand tight" if you cant remove it by hand the screwdriver / hamer method works well, a bit messy and please be aware of the temperature of your engine oil.
#20 mmgemini
mmgemini
    Old Hand
  • Settled In
  • PipPipPip
  • 4,407 posts
Posted 04 May 2008 - 07:50 AM
How do you manage to get your hands in there...In fact how do you manage to reach the damn thing....
I'm seriously thinking og going remote for mine.....
mike
mike
