300Tdi Tapping Sound
  • Please log in to reply
5 replies to this topic
#1 DeanB
DeanB
    Newbie
  • New Faces
  • Pip
  • 18 posts
Posted 05 May 2008 - 10:23 PM
Has anyone got a Disco 300Tdi that has a tapping sound from the engine bay ? i have set all the tappets to 0.20mm which is the correct gap but still have this annoying tapping sound that increases speed when revved so this has to be a crank problem, i have been told it could be a dodgy fuel injector but i have slackened each and every pipe off but still no difference in noise so now i am wondering if it could be a problem with the vacuum to the brakes.
Someone must have experienced the same problem, please let me know if you managed to cure it, would be much appreciated.
Thanks
Dean :blink: :unsure: :(
#2 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,140 posts
  • Location:Third rock from the Antarctic - 5141.8'S 5750.5'W
Posted 05 May 2008 - 10:31 PM
Check the vacuum pump and the fuel lift pump as both are prone to tapping/clattering noises and of course both vary with revs.
Also I assume you checked the rotator caps were all still in place and intact when you did the valve clearances?
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#3 DeanB
DeanB
    Newbie
  • New Faces
  • Pip
  • 18 posts
Posted 05 May 2008 - 10:42 PM
Yeah, all rotator caps all still there, will deffo have a look at the vacuum pump tomorrow, a couple of people have said it could be the problem.
Thanks for the reply
Dean
#4 Thys
Thys
    Old Hand
  • Settled In
  • PipPipPip
  • 253 posts
Posted 06 May 2008 - 02:54 PM
Thanks
Dean,
My Discovery 300 Tdi had a metallic clapping noise, also speed related, checked tappets, all pulleys, removed the timing belt cover to check for something catching, found none, eventually the source was the steel cupped disk on the back of the serpentine belt crank shaft pulley. It was slightly out-of-round, and touched the timming belt cover lip, but only when rotating at idling speed and higher. I eventually removed the dished cap, but installed a propper dust seal in the timing belt cover, and no more tapping noises on my Tdi..... : ;)
Thys
Member:Land Rover Owners Club Southern Africa
1996 Discovery I 300 Tdi Auto 3 Door
#5 DeanB
DeanB
    Newbie
  • New Faces
  • Pip
  • 18 posts
Posted 06 May 2008 - 10:17 PM
Dean,
Thanks for the comments, All done now, did turn out to be the vacuum pump, removed it from the engine and started it up, hey presto... no tapping. Went to the Landrover garage at Stocksbridge which i can highly recommend and bought a brand new one in box for 50.
Sounds fantastic now
Dean
#6 nicks90
nicks90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,456 posts
Posted 07 May 2008 - 10:06 AM
also check the exhaust manifold gasket. that can make a tapping sound if it leaks slightly from a pinpoint failure.
also worst case scenario, head gasket failure at the very back of the head (venting to the engine bay instead of oil or coolant galleries). put your hand between the engine and bulkhead and feel for any 'chuffing' or sooty deposits around that area.
WWW.YORKSHIREOFFROADCLUB.NET
Familly friendly 4x4 club. Monthly RTVs, nav scatter, clubman challenges and pub meets.
