TD5 - Dual Mass vs Single Flywheel
  • Please log in to reply
14 replies to this topic
#1 SteveG
SteveG
    Old Hand
  • Supporters
  • 2,826 posts
Posted 06 March 2009 - 12:49 PM
Looks like my clutch and potentially the DMF will need changing out soon.
What's the verdict on replacing it for a single mass flywheel and uprated clutch kit?? Rakeway do one for the TD5 including an uprated AP clutch for 495 +VAT
What are the pros and cons?
Cheers
Steve
#2 smo
smo
    D-Lander Crazy
  • Settled In
  • PipPipPip
  • 1,804 posts
Posted 06 March 2009 - 01:55 PM
I'd check the DMF first before even thinking about it - essentially if its not broken dont fix it!
D-Lander for sale.....PM me! http://forums.lr4x4....showtopic=69130
#3 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,084 posts
  • Location:Third rock from the Antarctic - 5141.8'S 5750.5'W
Posted 06 March 2009 - 03:00 PM
Pros - getting rid of a crappy flywheel that might break
Cons - fitting a (potentially) crappy clutch centre that might break
Can't think of a Land Rover model made in the last 20 years with a sprung clutch plate that doesn't have at least some reputation for having a bell housing full of springs and rivets due to the centre falling out of the clutch - at least it doesn't happen on the Td5 because there aren't any springs :)
If the AP clutch is decent enough then no problem, but I'd be worried about the usual record of springs in clutch plates on Land Rovers which ain't great :unsure:
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#4 Turbocharger
Turbocharger
    Old Hand
  • Settled In
  • PipPipPip
  • 2,761 posts
Posted 06 March 2009 - 03:03 PM
Can't think of a Land Rover model made in the last 20 years....
[pedant] Any of those with PRND321 written on the gearstick... :P
Without the DMF you might see increased NVH into the cabin but IIRC you're running lumpy tyres so I don't see a big reason to keep it. How are you sure it's knacked?
John Bickerton
www.teamnutter.co.uk
Home is where the heart is where the DVLA think you live
#5 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,084 posts
Posted 06 March 2009 - 03:31 PM
I said "...with a sprung clutch plate" I don't think you will find one of those in one with a PRND321 :P
[/pedant]
#6 disco_al
disco_al
    Old Hand
  • Long Term Supporters
  • 1,867 posts
Posted 06 March 2009 - 03:54 PM
DMF's will usually rattle when on the way out. Check it when in bits, if it's blue, then bin it. If it has small radial cracks - bin it. Better still, just bin it.
1998 Disco 1 300 TDi ES Spec in Oxford Blue - Steering Guard, Safari Snorkel, T-Max Split Charge System, Allisport Full Width Intercooler, Tweaked Injector Pump, TD5 Headlight Upgrade, EGR Removed, Stainless & Silicone Hose Kit, De-Cat Pipe, A Bar, 2" Lift with Procomp ES9000's, Bearmach HD Blue Springs, BFG AT's in 235/85/16 flavour and more to come......
#7 SteveG
SteveG
    Old Hand
  • Supporters
  • 2,826 posts
Posted 06 March 2009 - 04:38 PM
I don't, but clutch is slipping intermittently and so will need replacing. As far as I can tell a number of people seem to have experienced replacing the clutch only to have to replace the DMF in a few months down the line. Given this I thought it's easy and potentially less costly/hassle in the end to replace them both.
Oh and yes lumpy tyres, noisy exhaust, the odd rattle every now and then ;)
Cheers
Steve
#8 pongo
pongo
    Member
  • Settled In
  • PipPip
  • 163 posts
Posted 06 March 2009 - 06:58 PM
The DMF in mine failed, leading to a bad rattle at idle, which affected the engine in that the poor old ECU was trying to sort out the inconsistent crank speed. I fitted the rakeway flywheel with an uprated clutch and release bearing. I also chose to go for a slightly heavier flywheel, as I want torque rather than power (the truck has a JE ECU and a Brunel intercooler, so not short of go anyway). Result, very driveable, plenty of torque, no rattle to speak of, so very happy. :lol:
#9 SteveG
SteveG
    Old Hand
  • Supporters
  • 2,826 posts
Posted 07 March 2009 - 03:55 PM
So it seems I can source a DMF and Valeo clutch kit for 300 inc VAT, but plus shipping, a saving of 270 over single flywheel and it has the benefit of being a known entity.
This clutch has lasted almost 4 years and 46K, so I hopefully new one will last that long too.
Autopost have the AP Heavy Duty Clutch kit for 95 + shipping which is 15 more than valeo one. Is it worth getting this one?
Cheers
Steve
#10 Keith Keir
Keith Keir
    Member
  • Settled In
  • PipPip
  • 146 posts
Posted 08 March 2009 - 11:08 AM
The DMF in mine failed, leading to a bad rattle at idle, which affected the engine in that the poor old ECU was trying to sort out the inconsistent crank speed. I fitted the rakeway flywheel with an uprated clutch and release bearing. I also chose to go for a slightly heavier flywheel, as I want torque rather than power (the truck has a JE ECU and a Brunel intercooler, so not short of go anyway). Result, very drivable, plenty of torque, no rattle to speak of, so very happy. :lol:
Sorry to thread steal but what was the rattle you heard? was it when you started up and shut down as well or just at idle ? I seem to have a weird noise coming from that area on start up and shut down sort of like a clunk clunk like somethings turning around and hitting something. Does this sound like yours at all ?
Thanks keith
#11 simonr
simonr
    Trainee shepherd
  • Supporters
  • 5,595 posts
Posted 08 March 2009 - 11:27 AM
That's not a good life-span for a clutch though. My 200tdi was on it's original clutch at 160k with no signs of slipping.
My Td5 is slipping intermittently at 60k - it slips at certain combinations of torque and rpm - but the rest of the time works perfectly. That leads me to think it's the DMF that is the problem rather than the friction plates.
To my mind it makes most sense to swap out the bit that is causing the problem?
I didn't know Rakeway did flywheels with more mass - that sounds like an excellent idea. More torque and loose some of the low end vibrations. Is there a down side other than the engine being less responsive?
Si
#12 pongo
pongo
    Member
  • Settled In
  • PipPip
  • 163 posts
Posted 08 March 2009 - 07:51 PM
Thanks keith
Hello Keith,
The springs in my DMF had failed, so the two masses were having an un-dmaped fight with each other. The noise was a very distinct rattle at idle in neutral. When taking up the drive, the two masses were loaded so the rattle disappeared. If your transmission is rattling at idel i neutral then it is probably the DMF. If so, get rid. Ask yourself why LR have not retained the DMF on the Puma engine, which in its Transit incarnation has a DMF.
#13 dirtydiesel
dirtydiesel
    Old Hand
  • Moderators
  • 2,513 posts
Posted 08 March 2009 - 08:07 PM
Interestingly, we used to fit solid flywheels in place of the dmf on tdci transits,
But a few of them went on to snap there crankshafts.
We now just use luk dmf and have no problems.
Dan.
Do. Or do not. There is no try.
#14 Turbocharger
Turbocharger
    Old Hand
  • Settled In
  • PipPipPip
  • 2,761 posts
Posted 08 March 2009 - 09:39 PM
Can anyone explain why a heavier flywheel increases torque? I can see it'd increase the inertia you start the car against when the clutch is slipping but the torque from the engine is still the same.
John Bickerton
#15 rick
rick
    Old Hand
  • Settled In
  • PipPipPip
  • 632 posts
Posted 11 March 2009 - 03:46 AM
It can't, it just changes the moment of inertia and kinetic energy.
Land Rover.
Helping put oil back in the ground for 60 years.
You can't get any greener than that......
