Fitting Disco '3 pin' rear axle
#1
Posted 01 July 2009 - 10:05 AM
#2
Posted 01 July 2009 - 10:42 AM
Hi Adam,How do I do this? Do i have to buy a new propshaft flange for the back axle? if so how do I remove the old flange from the disco axle?! Help!!
I've never done this myself but I've read comments/threads on here about it. You do have to replace the diff drive flange and I believe it's pretty straightforward to do.
Do a search on here, I'm sure others have covered it and there's something in the Tech Archive about it.
HTH.
Mark.
#4
Posted 01 July 2009 - 11:19 AM
#5
Posted 01 July 2009 - 11:21 AM
1991 (late) Range Rover Classic Vogue SE,4.0 Serp cross-bolted V8, MegaSquirt, LT230, 33" Simex JT2s, X-Brake, Full cage, tank guard, tree sliders, TDS 9.5 with Bow1, Southdown front bumper, HD rear bumper, Ali rear floor, Ali rear tailgate, Twin electric fans, cage mounted X-lites, 10 spline(!) ARB in the rear.
#6
Posted 01 July 2009 - 11:51 AM
#7
Posted 01 July 2009 - 12:28 PM
#8
Posted 01 July 2009 - 05:57 PM
#9
Posted 02 July 2009 - 03:45 PM
I have a defender 300tdi, which as standard had a 4 bolt rear propshaft flange.
I am fitting 300tdi disco axles, this pair has a 3 bolt (with rubber coupling) propshaft flange.
As an aside question, do the axles all have the same ratio, can I expect any difference?
#10
Posted 02 July 2009 - 03:52 PM
I think everyone understood that Adam. Jericho's comments still apply, you need to replace the 3 bolt Disco flange with a 4 bolt Defender one.I think there may be some confusion....
Diff ratio's are the same between the 2 vehicles so you will not notice any difference. It is the Disscovery transfer box which has a higher ratio, in high range, in comparison to the Defender.
Regards,
mark.
#11
Posted 02 July 2009 - 04:42 PM
Regards,
mark.
I'm not sure they did, if so do I really need to buy a 200tdi rear prop? If so why?
PS. will I have to set up any bearings after taking off the old flange? I read the tech article and it says for some you will for some you won't..
#12
Posted 02 July 2009 - 06:23 PM
I don't see why your prop won't fit, unless the flange ends up in a different position longitudinally to that which your original one was in. I'm wondering now if the nose on the Disco diff is longer than the Defender one, or even shorter.I'm not sure they did, if so do I really need to buy a 200tdi rear prop? If so why?
I don't think you need to set anything up as regards the diff, just tighten the flange retaining nut to the specified torque.
Hopefully Ralph or Les can confirm the prop shaft length conundrum.
Mark
#13
Posted 02 July 2009 - 07:51 PM
If I understand correctly you are fitting a Discovery 300TDi rear axle with the three bolt flange to a Defender 300TDi that uses a 4 bolt flange. In which case you won't need a new propshaft, just change the flange as described above.
However if the axle is staying on the Discovery, when you change to the 4 bolt flange, you would need to replace the propshaft as well so that it has the correct 4 bolt flange from a 200TDi Discovery.
I hope this helps
Pete.
300TDi Auto 90.
"Do as little as possible, and that unwillingly. For it is better to receive a slight reprimand than to perform an arduous task"
#14
Guest_noggy_*
Posted 03 July 2009 - 12:16 AM
all you need to do, it swap the flange.
because other than the flange the 300def and 300 disco axles are exactly the same.
