Front Door Motor / speakers / parcel shelf
  • Please log in to reply
6 replies to this topic
#1 siearl
siearl
    freelander1980
  • Settled In
  • PipPipPip
  • 585 posts
Posted 10 July 2009 - 07:24 AM
I have a 99 S plate 3dr freelander. The front drivers door was working on the central locking but has now stopped. It wil stil lock off the remote but won't open. Has anyone any ideas and how easy to sort.
The second question is with regards to the front speakers does anyone know what size they are as hoping to try and replace them.
Lastly i have been looking at the load covers for the freelander can anyone tell me if the rollar one will fit and if not whre to get a reasonably priced rigid one or has anyone attempted to make there own.
Thanks for your help
Si
MSA Unit: Panther Response
#2 Mark
Mark
    Diesel Head
  • Supporters
  • 3,290 posts
Posted 10 July 2009 - 08:49 AM
Can't answer the fist two, but the roller cover only fits the 5 door models. The 3 door ones have a solid plastic affair, which if you want a genuine one, is 'kin expensive! I have been keeping my eyes open for one for some time noe - they do turn up on eBlag tho, and someone is producing a copy, but I have no idea how good they are...
hth
Mark
[:o|===|O:] 2001 110 TD5 Doublecab
[O]====[O] '91 200 Tdi Disco (RIP) & '96 300 Tdi Disco
Help keep this forum independent - click here.
#3 siearl
siearl
    freelander1980
  • Settled In
  • PipPipPip
  • 585 posts
Posted 10 July 2009 - 10:17 AM
Thanks thats what i thought that the rollar ones only fitted the 5 door model and like you say there are not a lot of rigid ones around a reasonable price. Think i might have to consider how hard it would be to make one with a bit of ply and sounding carpet
#4 LR NUT
LR NUT
    Old Hand
  • Settled In
  • PipPipPip
  • 412 posts
Posted 10 July 2009 - 11:25 AM
My mate has a 3 door and he tinted the rear windows himself and it looks not bad keeps prying eyes out of the boot it cost him about 7.95 a roll and think he bought 3 rolls of window tint film dont know if you'd do that rather than making a cover
Disco 2, V8 RIP Rolled & Ditched
Disco 2, Td5
Freelander 1, Td4
#5 siearl
siearl
    freelander1980
  • Settled In
  • PipPipPip
  • 585 posts
Posted 10 July 2009 - 04:01 PM
Was thinking about parcel shelf to mount a couple of speakers justt the prices of them to then cut it up
#6 mayanbilly
mayanbilly
    Newbie
  • New Faces
  • Pip
  • 12 posts
Posted 10 July 2009 - 08:59 PM
[quote name='siearl' date='Jul 10 2009, 08:24 AM' post='413075']
Thanks for your hel
Hi I have the same problem as you regarding the drivers door lock,
so will hope someone answers your question,,good luck..
mayanbilly
#7 LR2luver
LR2luver
    Newbie
  • New Faces
  • Pip
  • 9 posts
Posted 26 July 2009 - 12:44 PM
I can't remember if there is a key you can use in RH door, but if there is, does the LH door unlock with key as well as the remote? If it does then it suggests the central locking motor on the RH door has a fault, ie wont operate in one direction, in this case unlock. Usually requires a new/replacement motor assembly if it's seperate, or a whole latch/motor assembly if not seperate.
You could try taking the door trim off, which would give you access to the speaker for measuring, but you could also apply 12 volts direct from the battery to the RH central locking motor. If you can confirm it operates in one direction, then reverse the wires to check the other direction, you will have eliminated all the other possibilities in one fell swoop.
