How many amps can the cigarette lighter take?
  • Please log in to reply
14 replies to this topic
#1 eds
eds
  • Supporters
  • 591 posts
Posted 24 July 2009 - 03:46 PM
Thanks in advance
What amps can the cigarette lighter handle?
Would it easily handle 15 amps?
Cheers
Ed
#2 Aragorn
Aragorn
    Old Hand
  • Settled In
  • PipPipPip
  • 2,970 posts
Posted 24 July 2009 - 03:53 PM
I doubt it would "easily" handle 15A
I wouldnt think the connector could be rated for much over 10A personally, and wouldnt even feel to great about pushing 10A thru it. The standard wiring will probably be rated for about 10A max too...
#3 lansalot
lansalot
    Old Hand
  • Settled In
  • PipPipPip
  • 570 posts
Posted 24 July 2009 - 03:55 PM
If you need to supply 15A to it, how about you wire in a (suitably fused and suitably current-rated) separate supply to a new socket, direct to the battery ?
!google ohms law
V=IR and all that stuff.. :)
That said, P=VI, and 15Amps and 12 Volts only equals 180watts. That doesn't seem like an awful lot.... So I had a look at what sort of power a typical inverter might supply. Was surprised to find most are around 150W.
You might find this useful:
http://www.dcacpower...terguide.htm#10
Bottom line: run a separate (fused and rated) line if you need 15 amps - and you should ditch the cigarette lighter as a conduit as well as I doubt that would be up to it. Sparks and fires could be involved.
How about some nice Anderson Connectors ?
#4 J@mes
J@mes
    Member
  • Settled In
  • PipPip
  • 189 posts
Posted 24 July 2009 - 04:04 PM
how much current does the fag lighter element actually draw, bearing in mind it is a direct short circuit until it pops out?
Land Rover Discovery 3 TDV6 SE
#5 FridgeFreezer
FridgeFreezer
    Director of authenticity
  • Supporters
  • 18,209 posts
Posted 24 July 2009 - 04:12 PM
From TSD who's bought, tested and melted every cig lighter plug on the market (and some that aren't) the max you can reliably stick down one is 8A continuous with a good quality plug and the pointy tip filed down slightly. Realistically I reckon 4-5A is about the limit of most of them. The wire to the socket is usually nothing bigger than 1mmsq which means absolute max ~15A if the plug would take it.
For anything serious I'd look at small Andersen plugs or similar.
Yes*
*No
#6 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,153 posts
  • Location:Third rock from the Antarctic - 5141.8'S 5750.5'W
Posted 24 July 2009 - 04:18 PM
Agree with the above - they are usually a poor connection designed for intermittent use only and not suitable for anything other than low powered devices.
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#7 eds
eds
  • Supporters
  • 591 posts
Posted 24 July 2009 - 05:00 PM
In case you were wondering it is for a travel kettle which is supposed to draw about 165 watts
Seems a bit pointless if the cigarette lighter can't handle it.
I will wire a new wire direct to the battery with a 10 amp fuse in and see how i go.
That leeds me to ask which is the positive feed on a cigarette lighter? the tip or the edge?
Thanks for all the help
Ed
#8 LandyManLuke
LandyManLuke
    Old Hand
  • Moderators
  • 3,451 posts
Posted 24 July 2009 - 05:16 PM
The centre.
The outside is the earth/ground connection.
Keep this forum independent, click here
#9 Retroanaconda
Retroanaconda
    Old Hand
  • Long Term Supporters
  • 5,933 posts
Posted 24 July 2009 - 05:58 PM
Mudstuff do ones rated at apparently 16 amps, just run a new (fused) supply to them :)
#10 RustyNissanPrairie
RustyNissanPrairie
    Old Hand
  • Settled In
  • PipPipPip
  • 543 posts
Posted 24 July 2009 - 07:01 PM
I've got those Sutar ones in my 110, really solid pieces of kit and far better constructed than a regular fag lighter socket.
#11 tommi
tommi
    Member
  • Settled In
  • PipPip
  • 124 posts
Posted 24 July 2009 - 07:15 PM
I installed one rated at 20A off ebay.
http://cgi.ebay.co.u...s=|293:1|294:30
It's a quality piece of kit, much better than the standard socket.
#12 discomikey
discomikey
    probably the quietest series in the world..... Honest....
  • Supporters
  • 3,790 posts
Posted 24 July 2009 - 09:38 PM
i bought a 15 amp cigarette lighter type socket for one of our tractors last year, and it has coped fine with powering the eleccy hydraulic control thingy on the feeder, along with the high power scales and the LCD screen aswell.
mikey
Mikey: small collection of series vehicles including Brian..
Design Engineer: Bowler Motorsport
#13 TSD
TSD
    Old Hand
  • Settled In
  • PipPipPip
  • 654 posts
Posted 25 July 2009 - 10:51 AM
"Your tax dollar at work" :lol:
It's a few years since I did this, so my memory may be wrong on exact detail, and there may be better stuff available now. At the time I was looking for a good quality plug to fit a standard in-car cigarette lighter socket. I was looking worldwide, and I bought and tested to destruction every likely candidate I found.
I never found a plug that was capable of a reliable 15A. (By reliable, I mean a continuous 15A for many hours without problems).
The sockets usually have a decent amount of metal, and using fat wiring helps conduct heat away, in short they aren't usually the problem.
The plugs normally have a spring in them which doesn't conduct heat well, and looses it's temper when it heats up, making the problem worse.
Good quality plugs will have a flexy copper braid up the middle of the spring, or some other method of preventing the current travelling through the spring.
If there is an inline fuse, that will get pretty hot running near it's rated current, and that can destroy the spring and/or melt the plastic body.
The plugs with the removeable red cap (converts them to a DIN style plug, if you didn't know) all appear to be a copy of the Hella design, and most share the same design flaw. They are usually a fraction too long, so when you plug them in to a 'real' cigarette lighter, they have a tendency to pop out on every bump. Filing off the tip a bit lets them seat on the spring which holds the ciggy lighter before it pops out. Obviously this doesn't apply if you use the accessory sockets, rather than a cig lighter socket.
Farnell sells a '15A' copy of the Hella plug which has a solid centre pin where the fuseholder normally is. They heat up less, having no fuse.
Marinco makes a decent plug and socket combo (each half is compatible with 'normal' versions, but offers a splash seal and a twist lock when used together.)
Either of those is reliable at 8A, maybe more if you use fat wire and are lucky.
#14 Bowie69
Bowie69
    Permanently befuddled......
  • 8,947 posts
Posted 25 July 2009 - 11:09 AM
You'll be popping fuses for a pastime then....
I = P/V = 165 / 14 = 12A approx = bye bye 10A fuse.
1980 2.25 Petrol FFR Lightweight (standard)  (Sold)
1991 (late) Range Rover Classic Vogue SE,4.0 Serp cross-bolted V8, MegaSquirt, LT230, 33" Simex JT2s, X-Brake, Full cage, tank guard, tree sliders, TDS 9.5 with Bow1, Southdown front bumper, HD rear bumper, Ali rear floor, Ali rear tailgate, Twin electric fans, cage mounted X-lites, 10 spline(!) ARB in the rear.
#15 Night Train
Night Train
    Old Hand
  • Settled In
  • PipPipPip
  • 1,154 posts
Posted 25 July 2009 - 10:18 PM
Cig sockets are variable. I got a cheap one from Ebay that arrived with a label saying not suitable for cigarette lighters!
Fortunately it was only going to supply a satnav charger.
