hobson Posted July 25, 2009 Share Posted July 25, 2009 Does anyone know if it's possible to remove the rear sliding glass from a 110 station wagon and replace it with something flat, like a sheet of ally perhaps? going to be building the storage in soon and was thinking about siliconing them up but then thought; if one gets broken and there's storage built behind it, that won't be fun. i know you can get the opening door things for them but really i want to keep it as standard as i can. anyone done or attempted this? Quote Link to comment Share on other sites More sharing options...
western Posted July 25, 2009 Share Posted July 25, 2009 You can remove the sliding side windows complete with froame, extract the rubber filler strip & drill out the rivets [lots of them] then get a shet of alloy cut to the full size of the side panel & fit it over the top with rivets around the edge. or just buy 2 88" rear side panels & fit them instead of the existing pamels. there's photo's of how to do that in the members vehicles forum. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 25, 2009 Share Posted July 25, 2009 pathfinder on here posted up pics of his being done. If you do a search for members and then look at threads started by him you'll find it. Looks really good. Quote Link to comment Share on other sites More sharing options...
hobson Posted July 25, 2009 Author Share Posted July 25, 2009 In an ideal world i'd replace the panel and make it like a 110 van, but that'dve been a job for before i painted! only just thought about the breakage issue, was going to seal them up with silicone. so i couldn't remove the glass and get some ally to fit in the frame? i'd rather not drill them out if i can help it... Quote Link to comment Share on other sites More sharing options...
cieranc Posted July 25, 2009 Share Posted July 25, 2009 No, the glass physically won't come out unless the frame is removed, by drilling the pop rivits. Once the frame is out, there's two countersunk screws on one side of the frame, the other side is cherry rivitted. Remove the screws and the frame will open up at one end, just enough to get the panes out. Then the new sheet will go in. If you do go down this route, please give me a bell. I'm still looking for the plastic runner strip that sits in the bottom of the frame channel. This part is now obsolete, and is all that's stopping me refit my windows properly! Quote Link to comment Share on other sites More sharing options...
hobson Posted July 25, 2009 Author Share Posted July 25, 2009 Cieranc, i tried pm'ing you twice but its saying i haven't sent anything, it looks like i'll be going for the full ally side route if i have to take them out anyway, so pm me or mail me at: el.traveller@yahoo.co.uk and we'll see what we can work out Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 25, 2009 Share Posted July 25, 2009 Link Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 26, 2009 Share Posted July 26, 2009 A 110 or a Defender ? You did say 110 ? On the 110 the glass will easily lift out. You can then if you wish replace the glass with alli panels. You can make them slide just like the glass to have access like the Alli-Cab conversions. http://www.alu-cab.co.za/ If a Defender get a pair of 88" sides and just replace the lot. HTH Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2009 Share Posted July 26, 2009 won't lift out on my 110 had to take the complete window frame out to replace one if the windows after it got smashed. Quote Link to comment Share on other sites More sharing options...
hobson Posted July 26, 2009 Author Share Posted July 26, 2009 its a defender 110 county, i was hoping i could leave the frame in in case i ever wanted to put it back to standard, and replace the glass with one sheet of aluminium to blank off the rear. they're the type of windows which are riveted in, so (according to a recent thread) easier to get out than the later bonded ones, but if i have to take the frame out to get the sheet in place of the glass, i may as well do what pathfinder did and cover the whole panel. Quote Link to comment Share on other sites More sharing options...
cieranc Posted July 26, 2009 Share Posted July 26, 2009 Got your PM's, and duly replied! Mike, my 110 glass panes would not come out without removing the frame. I believe the Defender ones to be bonded in. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 26, 2009 Share Posted July 26, 2009 All the 110's I've looked at had series windows fitted. The glass was easily removable. Ceiran. IIRC you have Defender windows fitted to yours. Maybe they were changed at the factory on the later ones. mike Quote Link to comment Share on other sites More sharing options...
