Fitting a Discovery rear axle to a 1988 90?
#1
Posted 29 September 2009 - 07:32 PM
I have my name on a Discovery rear axle (Wish to replace with mine as I want discs all round) It comes with new pads and is even painted ready to fit with all the lines for £50 (BARGAIN)..
How easily is it to replace the axle with the one on my 90?.. I have had the rear springs and shocks off and one of the trailing arms so I know everything should un-bolt easily!.. My main concern are the brakes? (Apparently it is a case of turning the "T-piece" around on the disco axle to mate up with the existing pipe work?).. Also my other worry is the A-frame joint?
I have use of axle stands, Trolley jacks, Hi-lift etc.
Also is there anything I should do before I fit the axle?. Such as replacing seals or perhaps brake lines?.. I am going to fit a brand new A-frame joint whilst I am at it.
Any advice appreciated!.
Many thanks.. Matt
1969 2a 88 - My Red pickup series, Rebuilt and my first road worthy land rover
1982 S3 109 - Nackered and getting used as a donor for spares
1988 D90 CSW - Daily drive, Converted to 200Tdi, Re-sprayed Yellow and much more!
#2
Posted 29 September 2009 - 07:42 PM
The only issues that come to mind are that the 300 series discos have 3 bolt flanges on the diff rather than the 4 that you will need. Other than that it should bolt straight on.
I couldn't comment on the brakes other than that if the Disco had ABS there will be 2 separate lines rather than a t-piece...
hth
Mark
[O]====[O]
Help keep this forum independent - click here.
#3
Posted 29 September 2009 - 07:52 PM
#4
Posted 29 September 2009 - 11:07 PM
#5
Posted 29 September 2009 - 11:21 PM
If the diff flanges are different, conversion flanges are available on the bay of ee's or elsewhere. Do a forum search.
I doubt it will be different.. The lad selling it promises it will fit straight on or I can have my money back.. He bought it to go on his mates but his mates lost interest in land rovers.
But I prefer to get some second opinions.
Can you describe what you mean by Diff flange?. Im guessing you mean the part which the prop shaft is bolted to using 4 x 9/16th bolts?.
Thanks..
#6
Posted 29 September 2009 - 11:27 PM
They can be swapped over anyhow, you can take the one of your current 90 rear axle.
#7
Posted 30 September 2009 - 09:33 AM
Disco 1 V8 3.9i LPG
Range Rover In Vogue 2 Door - awaiting restoration.
Range Rover CSK No.120 - 4.6, stage 3 heads, upgraded cam.
#8
Posted 30 September 2009 - 10:12 AM
edit: seems that the late V8's (Microcat says Chassis VA541628 on) didnt have this coupling, and just used the same prop as 200 series discos.
#9
Posted 30 September 2009 - 10:21 AM
Take the oppurtunity to examine the trailing arm mounts for corrosion around the welds and also check the diff pan. Depending on how much of a rebuild you want to do i would either completley strip down, repaint, new seals and bearings, new pistons etc etc or just whack it on. Paddocks do a 'rear bolt kit' for about £20 its worth buying. May aswell fit new brake lines while your at it and a new rear flexi that way you know its good. While you have the axle on the bench take the oppurtunity to use a hex/flank drive socket to undo the bleed nipples, bleed bolts and brake pipe unions on the calipers BEFORE you have to do it laid on your back/eating wheelarch with DOT4 running down your sleeve and skinning your knuckles on the springs.
#10
Posted 30 September 2009 - 01:32 PM
#11
Posted 30 September 2009 - 07:22 PM
i fitted new discs and pads
mine was a bit rusty so i did have to sort it and paint it.
1986 110 disco 200tdi. 1989 90 disco 200TDI engine.
Member of Cornwall and Devon Land Rover club
